Old 09-11-2018, 09:41 PM   #1
Camcar
Drives: 2010 RS/SS
Valve spring advice
I was driving down the highway yesterday home from work, cruise control on, 63 mph in 6th gear, and my engine started missing. Felt like it was starting to run out of gas, kind of. Traction control light came on. Gauges all read normal, I didn't hear any noises, so I kept driving about another mile and it got worse. As I came up to an intersection and to a stop all of the lights came on and I could hear a click from the engine, so I shut it off. Got out and popped the hood and everything looked normal. Checked oil and it was fine. Had it flatbedded to the dealership because when I bought the car 20k miles ago I also bought an extended warranty for up to 100k miles, and I figured that would be the best place to take it. Got a call from the dealership and they told me I have a broken valve spring on number 4 cylinder (LS3, 72k miles). They asked if I had replaced the springs with aftermarket ones, because the ones in there didn't look like original springs, and they wanted to make sure they all match. I told them no. So they're saying that the warranty company probably won't pay to replace all of the springs so they match- just the broken one. Any advice? Does it sound like they're trying to rip me off? Thanks for your thoughts on this.
Camcar is online now   Reply With Quote
Old 09-11-2018, 10:59 PM   #2
theflea42
938 of 1524
Drives: 2013 Hot wheels edition camaro
I built a brand new 5.3 liter engine for my s10. I put in a comp cams camshaft along with a matching set of valve springs. One of these new valve springs broke around 15k miles, and the engine swallowed the valve. The comp cams tech people said it was a myth to have to replace all the springs. They just said to replace the broken one and it would be ok.
So, I built another engine. I bought a new valve spring to replace the broken one, and it's running just fine, about 24k miles and so far so good.
I'm guessing the ls3's have dual valve springs?
theflea42 is online now   Reply With Quote
Old 09-11-2018, 11:14 PM   #3
JOURDAN
Drives: 2010 Camaro SS 2SS
If they understand how to set seat pressure then it wont matter, just fix the broken one with OEM or other spring.
Stock cam? if OEM, they will know the spec.
JOURDAN is offline   Reply With Quote
Old 09-12-2018, 08:31 AM   #4
Camcar
Drives: 2010 RS/SS
Thank you for the replies. Great information. I will bring up the seat pressure point with them today. I got the feeling they were thinking they would be happy to have me pay for all new springs other than the one that broke out of pocket. They were saying the warranty company would probably only pay for the one. Stock cam, as far as I know... I bought the car with 52k on it, and it's run perfectly until this happened. Wondering why anyone would have replaced all of the springs...? I don't think the LS3 has dual springs, from what I've read, but I could be wrong. Thanks again, you probably saved me a lot of $$!
Old 09-12-2018, 11:03 AM   #5
suprchrgd
Drives: 2015 2SS 1LE
my car started doing this last night on my way home from work and you described my issue exactly. Looks like I'll go home and pull the valve covers off and see if I have any broken springs. i have about 24k miles on my btr cam and springs...
i'm also getting a vibrations coming thorough the tranny, that i can fell hear through my shifter...
"496WHP/451TQ": btr stg 4 cam with all the goodies, kooks 1-7/8" headers,k&n intake,vmaxx tb,mgw,rxt,bmr 1.5" drop springs,bmr poly cradle bushings,bmr toe rods,bmr trailing arms,bmr uca,bmr diff bushings
suprchrgd is offline   Reply With Quote
Old 09-12-2018, 01:38 PM   #6
Russell James
Russell James's Avatar
Drives: two 5ths and a 1st
All LS3s came OE with single Beehive springs.
Early years were yellow, later blue. A '10 would have been yellow beehives.
Ask them what would cause them to think they were not OE springs?
To determine if it needs one or 16, one would need to use a - on "on head spring pressure tester" and measure seat spring pressure. They all need to be very close. A weak spring about to break will be very obvious. If they don't know how to measure spring pressure on the head, the tech is clueless.
In drag racing, all the top classes - pro stock, top alcohol, nitro... all regularly check spring pressure between runs. When one all the sudden goes weak, out it comes.
Here is a tool to check spring seat pressure. A bad spring will be very obvious. It will have very weak pressure and soon there after break.
https://www.jegs.com/i/LSM-Racing-Pr...00SLC/10002/-1
Old 09-12-2018, 05:00 PM   #7
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
Originally Posted by Camcar View Post
…….I also bought an extended warranty for up to 100k miles, and I figured that would be the best place to take it. Got a call from the dealership and they told me I have a broken valve spring on number 4 cylinder (LS3, 72k miles)…....
Change all the valve springs. Even with the stock cam, even the beehives will eventually wear......hell, one has already and there's no telling how many others might be ready to give up the ghost.
If after haggling with the warrantee company you still have to pay for the other 15 springs.....then so be it.
Bottom line......the other 15 need to be tossed.
IMHO, of course.
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci Solid Roller LT4
2014 Chevy SS --- 429ci LS3
KW Baraka is offline   Reply With Quote
Old 09-12-2018, 08:39 PM   #8
Camcar
Drives: 2010 RS/SS
Thank you for the support. I will for sure ask them why they think they're not original springs. And great to know that they should be the yellow beehives. I'm concerned too that since one broke others might do the same. I'm just glad I asked here, so when I talk to him again I can sound like I know what I'm talking about. Thanks again.
Old 09-13-2018, 08:56 AM   #9
Russell James
The blue beehives are really good springs. If it were me, I'd see if they will go for installing all 16 as blue. May have to pay for 15, but worth it to get a fresh set of good springs.
Old 09-13-2018, 09:21 AM   #10
metrogdor22
Drives: 2013 2SS M6
I'd replace all of the springs for peace of mind, even if I had to pay for them out of pocket. That's chump change compared to the time and money involved if another one breaks and drops a valve into your motor.
2013 2SS M6 - Custom cam w/ miscellaneous valvetrain upgrades, ported heads, longtubes, CAI, CTS-VR lifters, Forza NPP exhaust controller - 500hp/460tq
metrogdor22 is offline   Reply With Quote
Old 09-13-2018, 10:23 PM   #11
marklsx
Drives: 2014 Camaro 1SS
I would replace all the spings, and while in there replace all the valve seals too.
2014 1SS - BTR Stg3, GMPP CNC Heads, Kooks LTs & cats, Magnaflow 2.5" Street w/Res X, Z28 CAI
marklsx is offline   Reply With Quote
Old 09-14-2018, 12:43 PM   #12
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
I agree ,cheap insurance against a future failure.
And anytime you replace valve springs you always change the valve seals , too cheap and easy not to .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 09-14-2018, 05:57 PM   #13
Camcar
Drives: 2010 RS/SS
Thank you all for the great feedback. This site is a great resource!
Old 09-16-2018, 11:02 AM   #14
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
You may have gone and bought someones demodded car......a car they took the cam out of also and left the aftermarket springs in which with a higher lift than stock cam last about 20-25k before needing checked and replaced....especially more if racing or higher than stock RPM limit..... any other tell tale signs its maybe been modified and demodded? you know you never get the money out of mods on resale....so the thing to do is pull them and in some areas you cant pass smog with cam headers etc.....
SO IMO your most likely demodded some and the warranty CO warranty is worthless most likely and a matter to take up with the dealer you bought it from as undisclosed alterations...but you bought it of course as is and if the warranty is worthless in the first place you should have never got it and be out that money or stuck paying for it further. And I would lean on the dealer...…. with big fat WTF is this in my engine I warrantied …. They sold you a CAR make them honor the repair at their cost for the undisclosed alteration of the vehicle they may not have known about,( though there usually is signs of a previous tune in the ECU supposedly), that they should rightfully should have known about by their inspection of the used vehicle which was represented to you as stock as is...… and could be a big price difference had you known it was prior altered by owner etc..... Just my thought I would be Steaming pissed. Hold a fuggin Sign on the Corner next to stealership pissed...…….
And BTW try Wongs performance engineering in Vancouver he is that good, check him on face book.
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr25% udp, LPW diff cover, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks billet badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
