Old 11-21-2013, 12:51 PM   #1
Cookie Monster
Belle Isle
Cookie Monster's Avatar
Drives: 2014 1LE
1LEs and car wash
I'm pushing my time constraints on storing my 1LE. I need to have it cleaned before storing and it's wayyyyyy too cold to wash it in the driveway. Too cold as in my outside water faucet has icicles on it. So I stop by "Mr. C's Car Wash" (a well know car wash in my area, not sure if local or nationwide) to see how wide the tire guides are. A worker wraps the 'wheel guide' around the width of my tire and there was at least an extra 3-4inches of clearance.
Should I go thru this car wash for this one time? Or am I still risking scratching the wheels and/or tires? Do I have to worry about anything else like ruining brand new car paint or splitter clearance?
Thx in advance, times running out in this crazy Michigan weather
2014 2SS
Credit to xVengeancex28
Cookie Monster is offline   Reply With Quote
Old 11-21-2013, 12:56 PM   #2
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
I would not do thru a guided car wash. I would use a self wash bay where you can just pull it in and wash it by hand yourself. And just because their guide template says there is room doesn't mean that the guides have the same center spacing as what the Camaro has. So by the time you start driving into the car wash both sides of your wheels might be closer to the outside of the guides on both sides and not centered on the same centerline as the guides.
Nick S is offline   Reply With Quote
Old 11-21-2013, 01:09 PM   #3
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Don't do it, the owners manual even tells you not to do it
Car Wash Guidelines
Notice: Automatic car washes are not recommended for ZL1 models and 1LE performance packages.
Old 11-21-2013, 01:10 PM   #4
Jims Mongoose
Jim
Jims Mongoose's Avatar
Drives: 2013 Black 2SS 1LE
Please dont'
Even if car fits just dont go through the machine. It beats the hell out of paint. Use self serve or handwash and watch them, because their buckets and mits are not always so clean. Personally I would do it myself at a self serve.
Jim
Easier to say when you are in Arizona like me, but I did the same thing in Connecticut when I lived there.
Jims Mongoose is offline   Reply With Quote
Old 11-21-2013, 01:12 PM   #5
Stock Boy
Stock Boy's Avatar
Drives: 2014 1LE
Aw hellllll no! Murphy is waiting for you at the end of the carwash in this scenario!
Stock Boy is offline   Reply With Quote
Old 11-21-2013, 01:12 PM   #6
wessolbuf1
wessolbuf1's Avatar
Drives: 2014 Camaro 1LE Summit White
There's a tag on the shifter from the factory that specifically says NOT to run it through an tracked car wash. I can only guess they have done some sort of testing on this to advise not to do it. My advise if your willing to pay to run it through a machine just pay a mobile detailer to come hand wash it. Good luck.
Ordered 10-1-13
TPW- 10-28-13
Delivered 11-12-13
wessolbuf1 is offline   Reply With Quote
Old 11-21-2013, 01:20 PM   #7
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Get a rinseless car wash, use warm water in the bucket from your house and just wash it in your garage
That's how I get through winters with my Daily
2012 Camaro 2SS/RS | 1968 Camaro SS | 2000 Monte Carlo SS | 2018 Regal TourX
ChibiBlackSheep is offline   Reply With Quote
Old 11-21-2013, 01:23 PM   #8
LuSe4
LuSe4's Avatar
Drives: 2013 Camaro 2SS RS LS3
Hey Chibi!
Don't do it. If not for the wheels, do it for the paint!
What I do in the winter is I fill my car wash bucket at home with soap and warm water. Then I drive to the spray wash and turn it on soap and spray the entire car. Then I take my nice, soapy, warm water and wash it up. Then just powerwash the soap off and dry that puppy.
-2013 Summit White over Inferno Orange 2SS RS-
-2014 White Diamond Silverado Z71 Crew Cab Short Box-
LuSe4 is offline   Reply With Quote
Old 11-21-2013, 01:31 PM   #9
Jims Mongoose
Jim
Total Agreement
Everything the sharp guys above said.
Oh wait, one of them was me. Everything all the guys above said excluding me.
We have to suffer a little for our girls, whether they are human or cars.
Seriously most garages can accommodate a bucket wash without getting everything wet.
Jim
Old 11-21-2013, 01:32 PM   #10
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
3 choices on automatic washes when I lived in MI
1) touchless- does about the kind of wash you'd expect.
2) 30 grit sandpaper rollers/brushes-does about the kind of wash you'd expect and scratches the paint.
3) Hand wash by guys with 30 grit sandpaper mops- Then goes through 30 grit sandpaper rollers/brushes.
Like someone else mentioned. Go to self serve. Then go back over it with a wet
microfiber when you get home and dry it off. Or wait until next weekend when it will probably be in the 60s again.
Old 11-21-2013, 01:35 PM   #11
ChibiBlackSheep
Hi LuSe4 Weird you kept that name without having an LS4 car anymore Although Lucithree doesn't sound as good lol
I try not to use the DIY car wash bay soap because the products that they use are so cheap and their soaps can easily strip your wax faster than you want it to.
The most I'll do is stop on my way home and use ONLY WATER to help hose off some of the salt / grime that might mark it up while I use a rinseless car wash.
Old 11-21-2013, 01:52 PM   #12
AlohaBR
Drives: Camaros...is there anything else?
There is a pretty good TOUCHLESS car wash on Dequindre south of 10mile, if that is close for you.
AlohaBR is offline   Reply With Quote
Old 11-21-2013, 01:53 PM   #13
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
1. Wash the painted surfaces with a good waterless wash, but make sure it has a detailer or a wax in it as well (I use 3D Detailing HD Touch which is a waterless wash with a Quick Detailer) this will keep the swirls and streaks to a minimum. Use the 2 Cloth Method, 1 to Remove the big stuff, 2 to buff/finish the surface
2. Use a good Wrap Cleaner/Care on the hood (I use Croftgate Wrap Care but first remove the dust using a duster but very lightly)
3. Clean the wheels with a Waterless wash and wax (I use 3D Waterless Wash on my wheels as it works great)
4. Apply a good wax, I use Mystic Diamond Cut Wax (which can only be purchased from my Detailer @ detailersedge.ca)
My Car is sponsored by Detailers Edge and 3D Car Care and is always in mint/clean condition and that is all that I have to do (I add a coat of Wax 1-2 times a month).
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 11-21-2013, 02:02 PM   #14
LuSe4
LuSe4's Avatar
I actually did think about "LuSe3". Although, most people didn't get "LuSe4" anyways. I have the same name on all of the forums I belong to. Oh well.
Sorry, back on topic.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
