02-14-2020, 09:07 AM | #1 |
Drives: 2015 2SS RS Join Date: Jan 2020
stock cai question
what is the hose on the left side of the stock cai(2015 ss camaro for ex) that runs away from cai and connects to engine area just below the oil cap? what is that hose called?
Darkness
02-14-2020, 09:11 AM | #2 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
I believe its a positive crankcase ventilation hose if it is running to the valve cover. I never saw the stock setup though.
02-14-2020, 09:14 AM | #3 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
02-14-2020, 09:50 AM | #4 |
mine is lose on the crank case side from when i pulled it off originally. now when i put back on it doesnt "snap" bakc on, its just on and i dont want it to slide off.....now i know what to call it when i call the dealer to purchase another
Darkness
02-14-2020, 09:31 PM | #5 |
Drives: 2014 1ss camaro Join Date: Jul 2017
if you haave enough slack cut about a half inch off and see if it tightens up.
02-15-2020, 06:49 AM | #6 | |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
02-16-2020, 01:19 AM | #7 |
i ordered the exact part to replace
Darkness
