#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction Discussions
AWE Tuning
Old 08-01-2017, 04:09 AM   #1
BFella
BFella's Avatar
Drives: 16' Supercharged 1SS
0-60 Times While Supercharged?
Okay, so I have a Maggie TVS2300 - Box tune with it and factory airbox and still at 6psi. I also have Michelin PS4S.
The best time I got tonight was 4.1 secs - I did have traction control on. I ran it multiple times but that's the best I got.
Should I be concerned at all with this?
760RWHP Magnuson 1SS
BFella is offline   Reply With Quote
Old 08-01-2017, 04:48 AM   #2
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
You need some track time. The street just won't tell you much. Too much spinning. I ran 10.82@129 on pretty much the basic Maggie tune. I wouldn't be concerned. I did have the drag pack and not on street tires. Have you had yours on the dyno yet? You should be close to 540 at the wheels.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
laynlo15 is offline   Reply With Quote
Old 08-01-2017, 04:59 AM   #3
BFella
BFella's Avatar
No, I'm gonna get it on the dyno I think this week to make sure it's all good. But yeah every launch I was spinning, so that could very well be it.
Old 08-01-2017, 07:36 AM   #4
laynlo15
laynlo15's Avatar
Oh that's it, too much power for good times
Old 08-02-2017, 11:04 AM   #5
1968ss350
1968ss350's Avatar
Drives: 1968 Camaro SS 350
hahaha man i have the same problem... with that kind of power we need the "drag pack" like laynlo said for sure. Slicks and skinnies. I am still running the stock good year 275s and they spin through first and second even when easing on it. I may get some wider wheels and tires for the street....
1968 Camaro SS 350 Lemans Blue
-350 10.4:1 comp, Edelbrock Etec 200 heads, Comp XR288HR cam,AED750dp worked, Tremec TKO 600, console gauges w/tic toc tach, Moser 12 bolt, 4 wheel Willwoods
Hyper Blue 2SS/6 speed, NPP, MRC, Nav, 5LQ 6 piston brakes, Black split spoke, Magnuson 2300 Heartbeat Supercharger, Flowtie upper grill
1968ss350 is offline   Reply With Quote
Old 08-02-2017, 11:40 AM   #6
grampa_ss
grampa_ss's Avatar
Drives: 2016 Camaro 2SS
Nitto 555R's. Good for DD and hook very well.
2016 2SS, MRC, NPP, A8. Procharger P-1X,Stage II,std bypass, 3.9, Alky Meth - 10.84 @129 - DA+2000
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth.
grampa_ss is offline   Reply With Quote
Old 08-02-2017, 11:58 AM   #7
DenverTaco07
DenverTaco07's Avatar
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot
What were your times before supercharger?
Also, with the heat down there, this may be a decent number. I was in Scottsdale week of July 10. one night at 10:30PM it was still 102° outside. And what's your altitude...like 1000 feet?
I'm at 6200 feet altitude and best I could get pre-supercharger was 5.7 seconds (yes we lose that much power up here). My best after is 4.7.
2017 SS 1LE | HBM | Vortech V3-Si supercharger (620RWHP and 575ft lbs) | PDR | Black Bowties | Illuminated Front Black Bowtie | Illuminated Door Sills | Smoked Tails | vented seats mod
DenverTaco07 is offline   Reply With Quote
Old 08-02-2017, 01:42 PM   #8
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
listening.... I have Michelins PS4S so I'd assume they are just as good as the 555's.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 08-02-2017, 03:02 PM   #9
BFella
BFella's Avatar
The Michelin PS4S are LIGHT YEARS ahead of the triple 555s lol.
Old 08-02-2017, 04:39 PM   #10
grampa_ss
grampa_ss's Avatar
had no idea PS4S hooked better that Nitto 555R drag radials. Learn something new every day.
Old 08-02-2017, 05:46 PM   #11
1968ss350
1968ss350's Avatar
PS4S is better than a DR?....
Old 08-05-2017, 05:34 AM   #12
BFella
BFella's Avatar
Didn't see the R :P
Old 08-05-2017, 02:58 PM   #13
attymf
attymf's Avatar
Drives: 2017 SS
I ran 4.2 best on street stock everything. Procharged with M&T's I am running 3.3 on the street. I dont do anything but mash the pedal. Leave everything on.
SS, A8, Procharger, M&T's and stuff...
attymf is offline   Reply With Quote
Old 08-05-2017, 03:36 PM   #14
bucknut2006
Drives: 2017 ZL1 A10, 2015 C7 Z51
The 555R's are pseudo drag radials. They require a lot of heat to stick and are not consistent. The NT50R is the better drag radial and closer to a Mickey Thompson.
2017 Camaro ZL1 - Nightfall Gray Metallic - A10 - Roto-Fab intake
bucknut2006 is offline   Reply With Quote
