05-25-2018, 07:21 PM | #1 |
silentmonk13
Drives: 2012 Camaro 2SS White & black Join Date: May 2018
Best value aftermarket exhaust brands?
Hey everyone!
I just bought my first car, a '12 SS a few months ago and I want to change up the exhaust. Some of the brands I saw were Borla, Magnaflow, Flowmaster, etc. I really liked the low rumble of a cat back street Borla exhaust but then saw it was around $2000. Yikes... not going to drop that much until I am more knowledgeable on some of these parts. What brands would you suggest and why? Looking for around the $600 range to start Thanks! |
05-25-2018, 08:33 PM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
If you're looking to spend ~$600 you can find yourself some mufflers but you won't find a cat-back for that much, unless maybe you want to piece together your own and have a shop put it all together (such as an x-pipe/resonated x-pipe in place of the factory h-pipe; removing the resonators; and the axle-back/mufflers).
I'm a fan of doing things once and doing it right (within reason of course - $$$) so I would save a few bucks and get what you really want. Personally I'm a fan of Magnaflow because of their "clean" and rumbly sound but that's just me, and everyone, of course, has their own opinions. Good luck!
05-25-2018, 08:48 PM | #3 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Honestly, if you want noise - start at the FRONT of the car. The 4 catalytic converters on this car really stanch the great noises these engines make.
Long tube headers through the stock exhaust is a great combo. Texas Speed's headers are under that $600 tag, too.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
05-25-2018, 09:27 PM | #4 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
You get what you pay for.
Borla or Corsa if you plan on keeping the car. |
05-25-2018, 11:01 PM | #5 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
05-26-2018, 09:33 AM | #6 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
We have a section for this. Go do some reading in the V8 bolt ons/exhaust section. All your answers will be fulfilled.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
05-26-2018, 10:04 AM | #7 |
Drives: 2011 Camaro SS/RS Join Date: Jun 2016
Not any cheaper than Borla, but look at Stainless Works too.
2011 SIM 2SS/RS L99/A6, Rotofab CAI, TSP LTs & hi-flows, SW Retro catback, BMR & Hotchkis goodies, MRR 017s & Nitto 555G2s
05-26-2018, 12:58 PM | #8 |
Hard to want.
Drives: 2020 red hot 1SS 1LE Join Date: Aug 2017
Solo cat back. Sounds great and no highway drone!!
05-26-2018, 01:48 PM | #9 |
Best value?
Legato makes an awesome sounding axle back that is $299 brand new. I think it is designed similarly to Flowmaster AT series. I was very surprised at the level of quality when I got it and it sounded great. But it's in my garage as I took it off in favor of the Flowmaster Outlaw Axleback. I am never 100% satisfied with exhausts on this car. Probably going back on soon. https://legatoperformance.com/collec...ro-exhaust-kit
05-26-2018, 06:27 PM | #10 |
05-26-2018, 06:46 PM | #11 |
05-26-2018, 06:58 PM | #12 |
05-26-2018, 07:07 PM | #13 |
05-26-2018, 09:16 PM | #14 |
LTH, no cats through the factory NPP is kinda nice
Tags |
aftermarket, exhaust |
