Old 06-30-2018, 12:38 PM   #1
VASTREETRACER
Drives: 2023 Camaro SS 1LE on order
Heated seats installed, not working
I picked up a set of 2SS seats and the heater control (radio face plate)from a 11 SS to install in my 10 1SS. I installed the seats, and the radio faceplate from the 11SS and the seats won't turn on. I know this has been done before but didn't see any threads on it. Am I missing something like a relay, controller or fuses that need to be installed? Went to drive it, getting an airbag light also. Is this normal? Gonna do a battery pull when I get home to see if that clears it
Thanks
Mark
2017 Camaro SS 50th anniversary, I sold it but 2010 Camaro SS, whipple, cam, full bolt ons and full exhaust made 739/656 RWHP/TQ on 93 pump gas
VASTREETRACER is offline   Reply With Quote
Old 06-30-2018, 01:04 PM   #2
seishuku
Drives: 2011 Camaro LS
The controls on the HVAC will send the canbus message for the seats, but if I recall correctly, the BCM has to be programmed to control the seats.
seishuku is offline   Reply With Quote
Old 06-30-2018, 01:57 PM   #3
VASTREETRACER
Probably just take it to the dealership to do that I'm guessing?
Old 06-30-2018, 10:57 PM   #4
seishuku
You can try, though from what I've gathered... Most dealers won't/can't do it, because the programming for features are tied by VIN and the software won't allow for individual options to be enabled (or whole "calibrations").
Quite frustrating to me, coming from the VW world, where all one usually has to do is change the module coding to enable/disable stuff...
Old 07-01-2018, 08:59 AM   #5
VASTREETRACER
Got the seats working... Airbag light still on though
Old 07-03-2018, 07:39 AM   #6
Rainbow1616
Rainbow1616's Avatar
Drives: 2011 Inferno Orange Camaro 2SS/RS
There is an airbag in the seat, make sure you didn't disturb that connection.
Rainbow1616 is offline   Reply With Quote
Old 03-16-2019, 04:44 PM   #7
Rocky1974
Rocky1974's Avatar
Drives: 2010 RJT 2SS M6 Camaro
I know this is an old post, but the '10s have a seat position sensor that the '11s+ don't have. The sensor, it's flag and it's associated wiring has to me moved to the '11+ seats or you will get an airbag light on a 2010.
2010 RJT 2SS M6, Kooks Long Tubes, NPP Exhaust, CAI Cold Air w/Jannetty Scoop, RotoFab Washer Bottle, Elite Engineering Catch Can, MGW Shifter w/ZL1 Shaft and Knob, 2015 SS Sedan Steering Wheel and Air Bag, 2012 Heater Hose Conversion, 2012 Power Seat Conversion, RS Head Lights,Gen5DIY RS Conversion Harness, LED Fog Lamp Bulbs, Backup Camera Kit, NLP Spoiler, SLP Splitter, ZL1 Rockers and Diffuser, Color Matched Shark Fin, RS Roof Mouldings, Painted White Stripes, WCC LS3 Emblems, Heritage Grille and Blacked Out Tail Light Panel w/Retro SS Emblems, 416 RWHP, 411 RWT, Tuned by BlueCat.
Rocky1974 is offline   Reply With Quote
Old 03-17-2019, 05:54 AM   #8
Pagliaro
RIP Betsy ( Vitara )
Pagliaro's Avatar
Drives: '11 SGM 1LT/RS
Send a message via AIM to Pagliaro Send a message via MSN to Pagliaro Send a message via Yahoo to Pagliaro
I'll be putting ZL1 leather suede seats from a 12 into my 11 1lt rs
First retrofitted 2014 mylink.
Pagliaro is offline   Reply With Quote
Old 03-20-2019, 01:28 AM   #9
Pagliaro
Pagliaro's Avatar
Heated seats work without programming if your radio has them.
Old 05-27-2021, 04:32 AM   #10
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
Wait what? How i thought the bcm had to be flashed....
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
Old 06-16-2021, 06:04 PM   #11
Pagliaro
Pagliaro's Avatar
Not at all in a 2011. I added 14 mylink and zl1 seats and my heated seats worked with no bcm programming.
Old 07-23-2021, 05:30 AM   #12
Pagliaro
Pagliaro's Avatar
I only needed to add the seats and faceplate with controls but I had already done that when I did Mylink install.
I have a 2011. When I added my oem heated seats they worked without any programming. 2010's have a different pin out on the seat harness so that may be an issue.
