02-01-2020, 08:33 PM | #1 |
Drives: Camaro LT 2012 Join Date: Jan 2020
Camaro 2012 Square 20/9" - different ET.
Guys,
I got front 245/45/20 8" OEM and want to buy another set of rears OEM RIMS 275/40/20 9" and put them up-front (I want the same front and rears) - and make it square. Should I be worried there will be problems with offset up front with new 20/9" ? Front is ET35 now. And I will have rim for ET40 (rears to put in front). Let me know guys. |
02-02-2020, 08:19 AM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
The factory rears fit up front no problemo.
02-02-2020, 09:19 AM | #3 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
They fit but it's tight. I've never had an issue. If you're worried, get some quality 5mm spacers. I recently did this, after much debate, and love it.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
02-02-2020, 10:36 AM | #4 |
+1 ended up doing the same to clear a brembo brake upgrade on my 1LT. As I researched this on this forum, seems like most have had no issues and have not needed to use a spacer.
Hotchkis Lowering Springs, Pfadt Balance Rear Sway Bar, BMR End Links, Cadillac ATS Front Brembo 4-Piston Brakes, VMAX Ported Throttle Body, VMAX Ice-olator, Volant Cold Air Intake, Magnaflow Resonated X-Pipe, Magnaflow Axle-Back Exhaust, JEGS Exhaust Cutouts, GM Strut Tower Brace, Hurst Comp Shifter, Heritage Front Grill, 3D Carbon Front Air Dam, T-Rex Lower Billet Grill, 3D Carbon Front Vendor Vents, 20x9 OEM Polished RS/SS Wheels Front & Rear
Thread Tools | |
