12-24-2013, 12:54 PM | #1 |
Drives: Camaro SS Join Date: May 2013
Starting problem, like flat battery, BUT not!
Hopefully this has not been asked before, i've checked everywhere with no luck.
I have a 2010 SS. Been very cold the past few weeks and the car started having trouble starting, turned over 4 times and just fired up before what felt like a flat battery. Felt like it was just about to run out of juice but started just in time. Had this before in other cars and just changed the battery and all is good..... However, I have changed the battery, and the car is still struggling to start. I fear if it does not start on the 4th or 5th turn it will not start at all, but so far has. Before winter it fired up first go! Checked wiring, and the recall fault and can't see anything. Big problem, i'm over the pond, in Sunny England, so no support what so ever! Any one have any ideas, before i replace the starter motor?? |
12-24-2013, 01:22 PM | #2 |
Drives: 2010 2LT RS M6 IOM FlwMstr Join Date: May 2013
I had a few no starts and I pulled my battery and hauled it in to get tested and they said all was well with it. Sometimes the car would start and sometimes not. I hauled the car into service finally and had them have a look at it. They said the grounding bolt was shorting out. I am pretty sure they were referring to the bolt as shown in the picture (lower right). Granted I have a 2LT RS but I would assume you may have a similar bolt on your SS.
They said it is a specialized bolt and had to order me a new one. I showed it to me and the threads were broken down due to arcing. As a quick fix they added some dielectric grease and put it back in and all was well. I came back when the bolt came in and they put the new one in. All at no charge. But going forward he is concerned that the threads in the body of the car were also breaking down from the arcing so it may give me problems in the future. If it does he will weld a nut on the underside of the body. |
12-24-2013, 01:25 PM | #3 |
You know...After posting the picture I am noticing 2 threaded studs in the lower right. I wonder if adding some nuts onto those would help the electrical connection instead of just relying on the one bolt.
12-24-2013, 02:04 PM | #4 |
Thanks for the quick reply, is the pic by the battery in the trunk?
12-24-2013, 02:15 PM | #5 |
12-26-2013, 01:46 PM | #6 |
Thanks for the reply over Xmas, had a good look and all looks good. Thinking it has to be a weak starter motor???
Dread to think of the shipping and tax costs on this!!! |
12-27-2013, 01:49 AM | #7 |
Drives: Camaro Join Date: Sep 2013
Sounds like a starter issue.
I wish there was a better answer |
12-27-2013, 08:57 PM | #8 |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Check to make sure the starter bolts aren't backing out, too. My car sounded like it was having a hard time starting and it was because one of the starter bolts was backed out almost half an inch.
12-31-2013, 11:49 AM | #9 |
Thanks Shibbs, will check that. Checked over all wiring and all looks good. Only when cold i get the problem. Think i'll to get a starter. Does anyone know a good place to get one, when i say good, either in Europe or someone that ships at reasonable prices and will sticker it as used to avoid the huge import taxes????
12-31-2013, 12:38 PM | #10 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
There was a tsb on the 2010 model involving the battery cable. Something about wearing through the cable wrap causing a short....running the battery down.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
12-31-2013, 01:48 PM | #11 | |
Captain Gingerbeard
If I were at home, I'd be able to check, my my work locks down the internet pretty badly... |
12-31-2013, 02:53 PM | #12 |
Avenging Orange, do you know if that was the recall for the cable by the starter motor, or else where?? I've checked by the starter and nothing out of the norm.
Shibbs, is it defiantly 100% the same starter, i know the engines L99 and LS3 are the same in both, but wasn't sure if the setup / belts etc were different?? Would be ideal as we can get Vaxhuall bits here.... Although not many V8 dealers :( This country is way to green. At least we are doing our bits to help warm the planet Thanks again to all those that are reading this and helping out, without you lot we would be stuck with the Eco Euro boxes! |
01-01-2014, 12:56 PM | #13 | |
http://www.camaro5.com/forums/showth...y+cable+recall
01-02-2014, 11:12 AM | #14 |
Thanks again for all your help. Stripped the starter motor today, bushes are burnt!!
Are there uprated start motors out there to fit our cars? Anyone know where to look?? Also, what could have caused the issue in the first place?? Only a few mods, 15,000 miles, no charger etc??? Any ideas i'd love to hear.... |
