12-22-2017, 09:23 PM | #1 |
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99 Join Date: Nov 2015
Data Logging - who's logging what?
Looking to see what parameters you guys are logging.
Thx
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires. |
12-23-2017, 07:06 PM | #2 |
CAR-DASHIAN
Seriously... nobody is doing this?
12-23-2017, 07:16 PM | #3 |
Drives: 2010 Camaro Join Date: May 2014
What for?
12-24-2017, 01:19 PM | #4 |
Drives: 2009 ZR1 Join Date: May 2010
Here is a screenshot showing most of what I'm logging
12-24-2017, 01:21 PM | #5 |
CAR-DASHIAN
Much thanks. Do you also log anything from the trans - shift points, rpm torque management?
THX
12-24-2017, 02:52 PM | #6 |
Out of curiosity, what do you do with all this information?
12-24-2017, 04:43 PM | #7 |
I have an M6. I dont log any trans stuff.
This data is used to tune your car. |
12-24-2017, 06:46 PM | #8 |
CAR-DASHIAN
Much appreciate!!!
C'Mon A6 guys... what are you logging!!! I'm just trying to learn. THX in advance
12-24-2017, 07:40 PM | #9 |
Drives: 97 Z28 M6, black! Join Date: Mar 2012
What's required to data log?
12-24-2017, 07:52 PM | #10 |
HP Tuners, EFI Live, SCT, and I think a few more that are able to do it. A wideband also helps.
12-24-2017, 07:55 PM | #11 |
CAR-DASHIAN
Hey Blake. Thanks for all the input.
Right now, I am just logging through the Torque app. Just wanting to get my feet wet before pulling the trigger on something like a Racepac or EFI Gotta walk before you run!!
12-24-2017, 07:56 PM | #12 |
CAR-DASHIAN
Besides - I need rims and tires before I pull the trigger on that HAHA
12-24-2017, 10:16 PM | #13 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
Some screen shots of mine here when I was tunig for E85:
http://streetntrack.net/topic/2490-t...&comment=61569
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
12-24-2017, 10:18 PM | #14 |
LSx FTW!!!
