04-22-2018, 05:05 PM | #1 |
Drives: 2013 2SS/RS 1LE (6spd) Join Date: Mar 2018
Can anyone help?
I hope I’m placing this in the correct location. I noticed a hole under the hood that the previous owner might have made. I am wondering if anyone can explain why someone would make this hole. Car is a ‘13 1LE. Thanks
Last edited by Panda1LE; 04-22-2018 at 07:56 PM. Reason: Posting pictures correctly |
04-22-2018, 06:25 PM | #2 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
I can't see the hole...photobucket disabled...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
04-23-2018, 04:34 AM | #3 |
Drives: 2009 ZR1 Join Date: May 2010
The only thing I can think of is they were running something down the valley under the wipers and wanted something to enter/exit engine bay there.
Also, could it have been mice? |
04-23-2018, 05:36 AM | #4 |
Drives: 2011 ss Join Date: Sep 2015
It looks to me like it was chewed.
I would think manmade cuts or tears are all going to have straighter edges or stress discoloration from bending. What is around the hole? Is it dirty or bubbled? |
04-23-2018, 11:24 AM | #5 |
Drives: 13 Camaro Join Date: Oct 2016
You had a rat or mouse
04-23-2018, 01:58 PM | #6 |
I am not too sure how or what caused this. I bought the car off the previous owner like this. I was just wondering if anyone knew why it would be there. But most likely everyone is correct and a rodent made its home in there at one time. I was thinking maybe to fish something through or for some type of mod. Thanks everyone
04-23-2018, 02:30 PM | #7 |
Drives: 2014 Camaro LS / 13 zl1 Join Date: May 2016
You should probably pull the cabin air filter out and check for rodents or more damage.
04-23-2018, 04:27 PM | #8 |
Hole
Why don't you ask the guy you bought it from?
04-23-2018, 07:40 PM | #9 |
Awwwww rats... it looks like you got rats
04-23-2018, 10:49 PM | #10 |
05-01-2018, 03:14 PM | #11 |
Can anyone help me with fixing that hole? I chcecked the filter area nothing in there besides a dirty filter. Now I want to cover that hole though. Any thoughts on what I can buy? Anything close to stock material?
05-02-2018, 03:33 PM | #12 |
You can buy the stock material to do it The part number is either 12 (92230866) or 16 (92195879) in this diagram. It appears to be 16 but the technical diagram is kinda hard for me to tell where they overlap. Is there an actual hole in the metal behind the material? If so, there shouldn't be one.
