08-17-2022, 02:08 PM | #1 |
Drives: 2013 ZL1 Convertible A6 BRM Join Date: Feb 2015
Hard Start Issues
I am having hot warm and cold starting issues with my ZL1. I use 93 octane premium from top tier stations only. No codes set. My mechanic thinks I need to run a tank of gas through it with injection cleaner and then use 100% gasoline, which in my area only 90 octane available. Any thoughts on my particular issue? My mechanic won't look at the car until I do this, primarily because no codes set. I am the original owner of this car, 15k miles.
2013 ZL1 CONVERTIBLE BRM A6
OHIO |
08-17-2022, 02:14 PM | #2 | |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
08-17-2022, 02:21 PM | #3 |
In all fairness to the shop, they are currently slammed and are shut down next week for vacation. The owner didn't want to let my car sit in their lot for a week, as he knows how particular I am about this car.
OHIO |
08-17-2022, 02:23 PM | #4 |
How would I go about finding a good shop? Seems to be hard to find here in SW Ohio.
OHIO |
08-17-2022, 02:23 PM | #5 |
In all fairness to the shop, they are currently slammed and are shut down next week for vacation. The owner didn't want to let my car sit in their lot for a week.
OHIO |
08-17-2022, 02:32 PM | #6 |
Take it to your dealer. Many things can cause what your experiencing without setting a code or being fuel related. If the condition is duplicatable, then the cause can be found.
08-17-2022, 04:15 PM | #7 |
Yep, good advice. Seems as though I could have gotten a few more miles out of this unmodified car before trouble struck!
OHIO |
08-17-2022, 07:24 PM | #8 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Age is just as bad as mileage or worse in some cases.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
09-21-2022, 04:28 PM | #9 |
Ok, so my car has finally been admitted to my usual garage that I take my cars to. We shall see what the issue is, hopefully I will get a call tomorrow with good news (hopefully a no parts required fix)!
OHIO |
09-30-2022, 12:42 PM | #10 |
Well I just got my car back from the shop. They say that my hard start issues are due to a bad battery. They say that it tests out at 395 cca, when hooked up to my car. However it tests close to 800 cca when it is unhooked from the car. Seems strange to me. If I do replace this battery, what are other people running? This is an Everstart. I have been buying these for 33 years and this is the first bad one I have gotten (just installed it in May 2022). Please note that this is an H7 battery, 1000 CA 800 CCA.
OHIO |
09-30-2022, 12:45 PM | #11 |
If you purchased the battery in May and it is bad now it should be covered and replaced for free
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions |
09-30-2022, 01:18 PM | #12 |
Drives: 2014 Camaro 1LT Join Date: Aug 2019
09-30-2022, 01:24 PM | #13 |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
Watching for your next update since I'm kinda shaky on it being the battery. Lots of threads on C5 for hard start issues with the V8s.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
09-30-2022, 02:13 PM | #14 |
I couldn't find any threads on ZL1 hard start issues. What were the primary causes?
OHIO |
