06-07-2021, 04:38 PM | #1 |
Catch Can - Motion Raceworks
So I ordered a new catch can from Motion Raceworks. I want to make sure I set it up right, so I called them. I’m NA btw.
So.. one of the gentlemen there told me to cap off the valley cover crankcase vent and hook the can up to both valve covers. So the catch can has two ports and yes, I can easily do that. What I’m not educated on is why? If I block off the valley crank vent, won’t the lower portion of the engine build pressure below the pistons? If I cap it off that is. Just seems to me that capping the bottom end, and opening the top end allows the bottom end to build pressure which can obviously be bad. Thanks all.
2010 Inferno Orange Metallic 2SS/RS - 6 Speed Manual
-BTR Stage 4 Cam, ID850 Injectors, E-85 Tuned, Corsa Xtreme Exhaust , Kooks 1 7/8 Headers, Melling Performance Oil Pump, ATI Super Damper, BMR Suspension: Sway Bars, Trailing Arms, 1” Lowering Springs, Differential Bushings, Rx Ported and Polished Throttle Body, VIS Racing Carbon Fiber Hood, Custom Painted - Body Kit, Entire Vehicle, ZL1 Addons Wicker Bill, MRR 20” Wheels, Powerstop Brakes, Koni SRT.T Shocks and Struts |
06-07-2021, 11:22 PM | #2 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
For the dirty side, catch can connects between the valley cover and intake manifold, behind the tb. Remove the short oem jumper hose. Just need to know the in and out on your catch can.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
06-07-2021, 11:52 PM | #3 |
Right. I get all that. But per my post, I was concerned about crankcase pressure. Just was curious why Motion Raceworks would want the valley capped off and just to vent the valve covers.
06-08-2021, 01:46 AM | #4 |
Drives: 2015 2SS/RS 1LE Join Date: Nov 2020
Motion thinks in a drag racing mindset, and the recirculating system is just an extra load of shit to please the EPA. Vent it to atmosphere. The reason to vent both valve covers instead of the valley and one valve cover is so you don’t get left with a bunch of pressure built up on one side. And it works fine trust me.
SE 1 7/8 tubes and 3 inch X pipe, Vararam DRX, TSP stage 2 cam, Deatschwerks 50 lb injectors, Motion catch can, E85. More to come.
06-08-2021, 10:10 AM | #5 |
GrINned & JUICEd
I'm stating how it needs connected. Connecting at the valley cover is basically the same as connecting at the valve or valve covers. Shares the same "air" space. Except on the LS3, the driver's side valve cover would need to be drilled. And the passenger side valve cover has the port for the "fresh" metered air and would need to be drilled. But then your PVC system wouldn't function very well. Because you'd be supplying air to the passenger side valve cover, the sucking it away to the catchcan. You would not be evacuating the crankcase's contaminated vapors. What's your concern with crankcase pressure? Are you concerned that the catchcan is restrictive and will therefore build crankcase pressure? It's not. Or is it the idea of capping off the valley cover? If so, there is no separation between the upper and lower part of the engine, air circulates through it all. Besides if there is excessive crankcase pressure, it will vent through the clean side, reversion. The hard line that's attached to the intake tube. That's why people put a catchcan on the clean, "supply", side. You stated you have a 2 port can, you would need to use a tee to connect the 2 valve covers or have a 3 port catchcan.
06-08-2021, 10:25 AM | #6 | |
Factory. Some catch cans don’t recirculate like you are saying. Motion race works being one of them.
06-08-2021, 10:34 AM | #7 |
YouTube-Car Nation Videos
Drives: 2010 Chevrolet Camaro Join Date: Nov 2019
If I were you, I would call Motion Race Works and ask why they are recommending it.
06-08-2021, 10:58 AM | #8 | |
GrINned & JUICEd
06-08-2021, 04:59 PM | #9 | |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2016
I'm assuming it's this can?
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit |
06-09-2021, 02:46 AM | #10 |
GrINned & JUICEd
Thinking it's a different one. Not sure if it's the same catch can but the other Motion video states to connect to each valve cover and block off the valley port. Ended up researching Motion somewhat. And then in the comments, someone asked about the port at the intake manifold. Motion's reply was to cap it. Surely they would have a different catchcan for each application. ???? I would prefer the can between the valley cover and intake. But, unless the breather has a check valve, the catchcan and crankcase evacuation would be of no value. And suck unmetered air.
06-09-2021, 07:02 AM | #11 |
I have a motion catch can bubba chill out lol he’s asking people who know... you are giving wrong information by continuing to tell him to put it on the dirty side. It’s not a one way flow catch can. And yes motion only makes one type of catch can....
06-09-2021, 09:44 AM | #12 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
I got chastised for being anal about torque ratings on a brake caliper bolt. This is just a catch can.
06-09-2021, 07:43 PM | #13 |
I misread their website, I thought it mentioned this being an improved design on a previous version but I think they were maybe just referencing improving traditional catch can designs that they've used before.
491 hp/438 tq
06-10-2021, 01:12 AM | #14 | |
GrINned & JUICEd
