Old 01-07-2011, 08:33 PM   #1
LT1Jeep
Ecstatic Camaro SS Owner
LT1Jeep's Avatar
Drives: Jeep(s) [1in pieces] and 2010 SS/RS
DIY Hardwire Radar
So I got tired of having the phine cord coiled wire hanging from the Valentine ONE near my mirror to the cigarette lighter plug. I decided to hard wire it, figuring there must be a power source up in the pod with the dome light and home link buttons.
First I got my stuff together: Power Probe for testing and cordless soldering iron and the usual wiring stuff.
Pop the white cover off the dome light using something soft to prevent marring the plastic.
Then pull the bulb and that housing can be pulled down. watch the clips and dont break the plastic.
There are two screws to remove under there.
Lower the unit and unplug the wire going to the HOMELINK module.
use a good pair of strippers and a razor blade to strip back some insulation instead of cutting through the wire itself. this is showing the black for ground, i already did the positive on the purple with stripe and taped it up. i like to solder all my connections and tape or heat shrink them, but a good wire tap or crimp connection could be used too.
Now the nice thing with a V1 is it can use a telephone wire for a power cord. But keep in mind the wires are very small gauge and can be tricky to strip properly. run it up behind the mirror into the headliner by unclipign the plastic cover.
i checked the connections and polarity once again to be sure.
reassemble in the reverse order and you are good to go. The only thing i wish was that it was switched power instead of constant because i need to remember to manually turn the radar off if im parking the car for any length of time. i wanted to use a different source but nothing up there was switched power and the dome lights themselves do all sorts of switching polarity and voltage drop things when they fade out. maybe with a relay it could be made to work. that could be next.
visibility is great and NO MORE WIRE dangle...
LT1Jeep is offline   Reply With Quote
Old 01-07-2011, 09:08 PM   #2
Inferno LSX
Supercharged LSX
Inferno LSX's Avatar
Drives: 2011 2SS/RS Black/Carbon Fiber
you could have gotten the power from the mirror
Inferno LSX is offline   Reply With Quote
Old 01-07-2011, 09:09 PM   #3
Inferno LSX
Supercharged LSX
Old 01-07-2011, 09:10 PM   #4
Inferno LSX
Supercharged LSX
Old 02-23-2011, 09:45 PM   #5
acuraelin
Drives: 2011 1SS
wow where did you get that inferno?
acuraelin is offline   Reply With Quote
Old 05-18-2011, 06:25 PM   #6
Camaro4Life2011
Camaro4Life2011's Avatar
Drives: Black Camaro 2LT RS with Sunroof
Hey guys I am having a little trouble. Attempting to hardwire the v1. Went to radioshack and they did not have any fuse taps. The v1 comes with a t tap. I was wondering if anyone went that route. Do you need to use invisicord? Thanks guys.
2011 Blk on Blk 2LT
[x] Perma-grin
[x]1000 Watt Dual 12'' Subs (******** Harness)
[x]Blacked out Bow-ties
[x]AACStyle Blue Footwell Lights.
[x]AACStyle Blue LED Dome Light.
[x]AACStyle Blue LED Trunk Light
[x]Knight Rider 54 Blue LED
[X]Valentine 1 Hard Wire
[X]Valentine 1 Concealed Display
[ ]20 %Tinted Windows
[ ]LED Underglow
[ ]Rear Footwell Lights
[ ]ABL Extension
[ ]Camaro RS Projection
[ ]Painted Calipers
[ ]Glove Box Light
[ ]Door Handle Lights
[ ]Cold Air Inductions CAI
[ ]AACStyle Plasma DRL
[ ]AACStyle License Plate LEDS
Camaro4Life2011 is offline   Reply With Quote
Old 05-24-2011, 05:06 PM   #7
Camaro4Life2011
How exactly did u remove the A-Pillar?
2011 Blk on Blk 2LT
[x] Perma-grin
[ ]LED Underglow
[ ]ABL Extension
[ ]Painted Calipers
[ ]Glove Box Light
Old 05-24-2011, 05:53 PM   #8
The Stig
knows 2 facts about ducks
The Stig's Avatar
it pops right off. Just pry at it with a trim removal tool and/or your fingers
Click to view my build thread
Old 05-27-2011, 12:25 AM   #9
Inferno LSX
Supercharged LSX
get the power from the Mirror. got the power cable and pins online. i purchased the bling mount for the V1 and they have a power plug that goes to the mirror
The Radar / Laser MEGA thread raqball Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 116 01-28-2017 11:04 PM
DIY : Radar Detector Hardwire Install Macamaro Camaro DIY & HOW-TO instructions & discussions 179 07-29-2014 07:30 AM
What fuse to hardwire to for radar detector? BaylorCamaro Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 7 11-22-2010 09:22 PM
Best Detector razorduck Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 85 09-11-2010 04:47 PM
Hardwire Radar Detector? mhennick Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 10 06-13-2009 10:27 PM
