04-19-2018, 01:08 AM | #1 |
Drives: 2013 CAMARO Join Date: May 2017
Nitro NT555 G2
Any thoughts on these tires? Looking to purchase some but not sure if these are good tires to have?
Performance wise? Wet Handling? Or Grip wise on the road? I’m getting some 285s and 315s What would you recommend on tires? |
04-19-2018, 06:48 AM | #2 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
I have the 315 on the back. Much better street tire than the goodyears...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
04-19-2018, 01:19 PM | #3 |
Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
I just put these on my car. Very pleased so far. 275's on the fronts and 315's on the rear.
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
04-19-2018, 01:34 PM | #4 |
Instagram: Sangstah
Great tire with good reviews for the price. Once my Invos wear out, I'll be getting some.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
04-23-2018, 01:52 PM | #5 |
Drives: 2013 LT2 RS Vert Join Date: Jul 2017
I just put these on my car when I got new rims two weeks ago. 275s on 9" in the front, 305s on 10" in the rear. I've been happy with them thus far. Have not had experience yet in wet conditions, but they ride similar to the stock PZeros, seem to have about the same road noise level - but what I really like about them is the sidewall and tread design look of the tire.
The price is certainly nice. The only negative that I see on the tire is they are directional, so you can't rotate them. |
04-23-2018, 07:54 PM | #6 |
Drives: 2010 2SS/RS Join Date: Dec 2009
I put 285s all the way around on 10s and 11s got a slight shake from 47-60'ish think it's just a balance issue. Need to find the time to take it up to discount and have them checked.
Orange Krush II
04-30-2018, 07:04 PM | #7 |
Drives: 2010 Camaro SS 2SS/RS Inferno Orang Join Date: Jan 2017
I have them and they suck at track days. After a full weekend they were chunking real bad and very greasy when they are hot. Street they seem ok
05-01-2018, 07:19 PM | #8 |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
I have them for my summer driver. They work extremely well, especially in the wet.
Do Not track these tires. Not the right application.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
05-01-2018, 10:18 PM | #9 |
Drives: 2011 2SS/RS Join Date: Feb 2016
Daily my 11 SS. have these in 275/315 setup. Work very well ( first geat wants to spin still LOL ) great in rain as long as your gentle. Great summer tire. Not meant for road coursing imho.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
05-02-2018, 06:20 AM | #10 |
Drives: 2013 SS Supercharged Convertible Join Date: May 2013
Spend a little more and get Michelin PSS’s. Everyone spends tons of money on all types of mods, but, get thrifty when it comes to one of the most important mods on the car. 30k mileage warranty, good in wet conditions, nice ride with low noise levels and handle great.
285-35-20’s all around. |
05-04-2018, 03:06 PM | #11 | |
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
05-04-2018, 03:10 PM | #12 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
Nitro NT555 G2
I have these tires on my car now (285 up front and 305’s in the rear) I still can’t hook from dig. It’s definitely way better than the Parelli’s, and Goodyears I’ve had previously. They have no trouble in the rain unlike the Goodyear eagles. I’m going to get R888’s next and hopefully fit some 315’s in the rear.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
05-04-2018, 03:43 PM | #13 |
Shimmy
Took the car back to Discount Tire for a rebalance and come to find out my new wheels are bent. Passenger side is .030ths TIR and the drivers is .017ths TIR. Hopefully I'll be taken care of.
Orange Krush II
05-31-2018, 12:47 PM | #14 |
Drives: 2010 Red SS/RS Join Date: Jul 2009
Cheap - I mean inexpensive
Yesterday I ordered 2 - 315s from Walmart online, $140 each. Discount Tire wanted double that.
