03-19-2023, 01:42 PM | #1 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Whipple 3.0 vs 2.9 comparison
Well I was able to get my brother Jake over today to give me a hand with getting the blower upgrade underway. Anyone who thinks the blower is just a small bump in size from 2.9 to 3.0 is completely missing the boat! Huge differences! The new 3.0 is TALL. Rotor pack is much shorter which will allow a higher critical speed (not to mention 4x3 instead of the old 5x3). The snout is now wide open (something the 2.9 couldn’t get even after porting). You’re able to bolt it down to the heads without removing the lid. And the difference in heat exchangers is crazy. The new HX is dual pass and massive…takes up the whole lid (the 2.9 used two smaller HXs as pictured below). Unfortunately for me the new pulley is 5-bolt with a bigger hole for the upgraded shaft diameter, so my 4-bolt 2.9 pulleys do not work on the new blower. It also appears that I can just bolt up my Katech 112mm TB without an adapter too, so that’s nice. More to come as this gets underway….
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
03-19-2023, 01:48 PM | #2 |
Drives: Chevy Camaro ZL1 Join Date: Feb 2023
Hopefully the new one is not as bad as the old one. Tons of gen 5 failures over the last two years.
03-19-2023, 01:55 PM | #3 | |
Also my 2.9 is 4 years and over 1100 crank HP…hard to complain.
03-19-2023, 02:20 PM | #4 |
Drives: 21 Lt1 Join Date: Dec 2016
Looks awesome!!!! Definitely some big differences. You going for over 1k whp?
21 Camaro LT1 Fully forged, Katech ported stock heads, P1X,3.7 upper and ATI w/ 8.25 lower, Stage 2 intercooler, Race B.O.V, Btr stage 2 blower cam, Btr Trinity intake, 103mm TB, F.I.C +30’s, Fore innovations, LPE big bore pump, Weld Lagunas Drag Pack. Circle D TC. Full Bmr upgrades, Keltrac rear shocks.
03-19-2023, 02:25 PM | #5 |
For sure. I was at 955 WHP with the 2.9, so 1K is definitely not out of the picture with the new 3.0. Not sure about my fueling though. I’m DI only with the LPE pump/+52% injectors/Fore Triple (no meth either). But buying the blower and 15” conversion was enough for now lol…I’ll add PI a little further down the road.
03-19-2023, 06:47 PM | #6 |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
I'm wondering if you should have the runners drilled and just plugged for now. I'm thinking about this myself on which way to go. Mag with plates or Whipple with pi mod. Gotta decide very quickly my season starts shortly.
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror |
03-20-2023, 06:08 AM | #7 |
Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
Josh- I think he meant the Gen 5 Camaros? Not the Gen5 motor (LT1) per say.. (not sure what he meant by tons of failures, as I scanned both Camaro5 and 6 forums and didn't see all these 'failures'. Where is the documentation to this comment?) If the Whipple 3.0 is as good as the ones on the boats with the super chillers, then they will be a good upgrade. Hopefully will compete with the 2650's out there...
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
03-20-2023, 06:15 AM | #8 |
Ted- Mike at Katech is working on the PI for the runners on the Whipple, and is close to release. Maybe give them a call to see the ETA. (May be cheaper then the Maggie with the TooHighPSI plates, but who knows)
03-20-2023, 08:54 AM | #9 |
BAMF SS
Spicy
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
03-20-2023, 09:12 AM | #10 |
Petro-sexual
That has all the cooling! WOW!!! You'll be in the 4-digits EASY.
Looking forward to your progress.
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
03-20-2023, 09:39 AM | #11 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
Agree...there have been some 2.9 issues on the LT platform but there are also plenty of us that haven't had any issues with them.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
03-20-2023, 10:27 AM | #12 |
Josh- keep that spare Bosch pump... mine took a dump during break in on the lift, so Whipple is sending another one ASAP... hopefully the car will be done by week's end unless something else fails...lol
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods Last edited by adamjwilson; 03-20-2023 at 10:41 AM. |
03-20-2023, 06:09 PM | #13 |
Negative my friend. I’m not using the Varimax pump (originally came with the 2.9) anymore and I’m not using the Bosch pump (that came with the 3.0) as the flow is only 4.4 GPM at 12 PSI or so (technically 1000 liters/hour at .85 bar, I looked it up on Bosch’s site), making it similar in performance to a stock LT4 IC pump. No bueno. I’m going with a Pierburg 150 which will do over 10 GPM at 12 PSI.
03-20-2023, 06:16 PM | #14 |
So a small update: the new 3.0 does NOT fit with the Katech AFM-delete valley cover. The hefty PCV boss on the cover interferes with the blower snout. Well, it did…but we broke out the die grinder for some “clearancing” action You have to be care not to get into the PCV plug sealing o-ring but this picture shows it about 60-70% of the way there before calling it a night. We’ll take a little more off, touch up the black finish, then hopefully bolt the damn blower down! I gave Mike @ Katech a heads up too so maybe they can address it during the next cover production run… or just grind away.
