Old 05-01-2023, 07:12 PM   #1
Blue 13
3P171 USAF Combat Arms
Blue 13's Avatar
Drives: 2013 SS/RS
Rear coil over thunk
I installed a set of AFE/Pfadt coil overs on all 4 corners. I wish I had the part number, but I’ll enclose a picture when I got them from a forum member. The car had Koni Yellows shocks & struts and upgraded FE4 springs. Zero issues. Now the car makes a very distinct thunk from the rear when going over a bump. I took it to a suspension specialist and he’s pretty sure it’s coming from the new coil overs as he tightened everything and we even removed things to rule them out (end links for example). We both think it’s either they are just that noisy or they could potentially be defective, which would suck as they were brand new but I wasn’t the original purchaser.
Has anyone else used these and noticed they are just loud? Thanks.
Blue 13 is offline   Reply With Quote
Old 05-02-2023, 08:23 AM   #2
fz4k98
Drives: 2013 1ss
I have viking coilovers on the rear and they do the same thing. It has been over a year now and the sound has not changed at all. It does change based on how tight i run the adjusters for compression and rebound.
Everything is tight and double checked on mine. I believe it is in the upper mount to body plate or the upper shock mount to body plate. I have considered putting a thin dense rubber pad between the plate and body but have not done it yet.
fz4k98 is offline   Reply With Quote
Old 05-02-2023, 08:55 AM   #3
Blue 13
Blue 13's Avatar
Drives: 2013 SS/RS
Thank you so much. That really puts my mind as ease.
Old 04-06-2024, 05:16 PM   #4
TOM KAT
Drives: 2013 Chevy Camaro SS
Viking Coil over thunk or clunk
I have the rear Viking Berserker Kit on my 2013 camaro SS and it also makes light thunk or clunking noises on rough roads. So far I changed the top mount bearings to the poly bushing. I also tried rubber pads in between the mounting plate. Nothing changed. I believe its the shock, but when I take it off the car and work it, it doesnt replicate the noise so Viking does not think its the shock. Anyone else have this issue.
TOM KAT is offline   Reply With Quote
Old 05-25-2024, 10:13 AM   #5
Ck1984
Drives: 2015 camaro LFX V6
my stock camaro seems to make a thunk in right rear too
enough so i was under there looking for broken welds and such
only had 67000km or about 42000 miles at the time
2015 2LT LFX 3.6L
FE2 Sport Suspension
MXO-6 Speed auto w/Tapshift
Aftermarket Oval mufflers
Ck1984 is offline   Reply With Quote
Old 05-25-2024, 06:21 PM   #6
SlowLS1
SlowLS1's Avatar
Even my Air Ride rear strut clunks, seems to be a common 5th gen issue.
SlowLS1 is offline   Reply With Quote
