09-15-2013, 04:00 PM | #1 |
WICKDSS
Drives: 2011 1SS/RS IOM LS3 Join Date: May 2010
ECS SC1500 Kit Installed! *Updated With Dyno Results!*
Yeah, here is another happy ECS customer! I finished the install after a total time of 1 1/2 days (12hrs) of tinkering around putting this thing together in my spare time. I am a newb when it comes to super chargers but not to building cars, but I took my time with this install. I installed the Squash Dual pump system a few weeks ago to support the future power increases. I'm still 2 weeks away (28th) from getting tuned again by Justin Kalwei in KC. Hoping for a safe minimum of 600rwhp with my TSP cam.
I would like to thank Chris, Shawn and Alex at ECS for putting up with my dumb questions and for putting out such a nicely made kit! Final Numbers were 636rwhp and 581rwtq on 91 octane and 9 psi! Thanks to Justin "Justune" Kalwei at The Tuning Station in KC, Mo. Also thanks to Andy at Squash Performance! For a flawless performing fuel system.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei 11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds. Last edited by TornadoSS; 09-28-2013 at 04:36 PM. |
09-15-2013, 04:03 PM | #2 |
Drives: 2010 Camaro SS/RS 6spd Join Date: Sep 2009
Sweet!
09-15-2013, 04:28 PM | #3 |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
Nice! You should be over 600hp....enjoy!
NY5thgen.com
09-15-2013, 04:44 PM | #4 |
Congrats! Looking Good!
09-15-2013, 06:56 PM | #5 |
Make your peace with God!
Drives: 2011 Camaro SS/RS M6 Convertible Join Date: Dec 2011
Are you running the restrictor plate?
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ UNDER MAJOR OVERHAUL!! |
09-15-2013, 07:22 PM | #6 |
WICKDSS
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei 11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds. |
09-15-2013, 07:27 PM | #7 |
You should be well over 600. I would say probably in the 625-650 range. If you add meth, you can get even more.
09-15-2013, 07:35 PM | #8 |
WICKDSS
That's what I'm hoping for. The meth will come later, since I have pretty much maxed out my budget at this time.
09-15-2013, 07:37 PM | #9 |
That's good, but also sucks at the same time. When you add meth, you'll need a retune.
09-15-2013, 07:43 PM | #10 |
Sold car...
Drives: 2010 Rally Yellow 2SS/RS #37115 Join Date: Oct 2009
Nice!
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust. |
09-15-2013, 08:07 PM | #11 |
WICKDSS
Exactly. It is expensive to keep adding things and getting retuned all the time.
09-15-2013, 08:10 PM | #12 |
WICKDSS
Quick question, on the BOV, FPR and Hobbs switch hoses, do they all need clamps? I'm not to sure I have any clamps that small? How about spring/pinch clamps?
09-15-2013, 08:13 PM | #13 |
I don't believe so. If I recall, it's low pressure and the ends are flanged to grip the hoses. If anything for reassurance, you can always zip tie them.
09-15-2013, 08:16 PM | #14 |
WICKDSS
Ok. It was a bitch to get them on there so I assumed it was tight enough. Just trying to avoid any surprises at the tuner, he's 3 hrs away.
