Old 11-21-2011, 10:57 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Question 1st to 2nd shifts slow
this is on a 2010 m6
Ok so its not grinding. Ive had me spells with that already. lol I got a new tranny and so far so good. But i im running it hard and i shift into 2nd it takes a moment to go into gear. never grinds or makes any noise. it just takes a sec to go in gear. is there something i can do to make it shift into 2nd faster? I have a hurst shifter in it. is there a better fluid i can run in it other than royal purple? all the other gears go in fast with no issue at all.
2010_camaro is offline   Reply With Quote
Old 11-22-2011, 01:03 PM   #2
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
I've had the same problem with 2nd gear refusal's at peak RPM. Best solution I've found is AMSoil MTG 75w-90.
There's a long winded explaination elsewhere, but suffice to say its a GL-4 not GL-5 as rec. by GM, but works much better for me. http://www.camaro5.com/forums/showthread.php?t=181782 Check here for the wordy version
Old 11-23-2011, 02:45 AM   #3
2010_camaro
ok thanks man
2010 1st - 2nd grind sixd8z V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 09-14-2011 07:22 AM
Camaros 1st & 2nd at Lime Rock! R Kern The Sports Lounge 3 05-30-2011 04:23 PM
AY6 1st to 2nd Grind c_LoW29 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 25 01-31-2011 08:25 PM
Sticky or slow shifts in cold weather BacktoGM V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 12-19-2010 10:59 PM
yep... slow shifts... scrming Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 30 07-19-2009 06:25 AM
