05-11-2021, 08:35 PM | #1 |
DONE-VALVE SPRING REFRESH.
Well picked my Camaro up today from the shop after having the BTR .660 valve springs swapped out after 23k miles, and had the 2 oil leaks fixed, oil pan and the cooler/heater block and the leaking Mishimoto thermostat replaced, and a new set of NGKTR6IX plugs installed, it had NGKTR6 V-Power's in it. I really never knew how poorly my Camaro was performing at rpm's above 6800 until I drove her home today with the new springs and plugs installed, wow what a difference!! It's almost like the day I took her home from the cam swap and felt the new found power!! Before when I got on it and was running her out to 7000 and above it felt like she just didn't want to go anymore. Been like that for a while. Now with the new springs and plugs she seems to have some more grunt and pull behind her, seems tighter if you know what I mean all the way up the rpm scale and now she will pull really hard all the way out to redline 7400!! Ans STILL wants to go!!
Man I didn't think a refresh of the valve springs would make that much difference, but it did, wow. I'm happy. Plus the cam lope at idle sounds a bit more crisper than it did before, maybe my imagination. I remember asking Bo months ago when he was doing his springs, how would you know when they are getting tired? And he said his engine would just lay over on the top end, and that was what mine was doing because now the top end is very strong again now. Thanks Bo. So you guys getting closer to your refresh time, don't go past 20k to do it like I did and have to deal with inferior performance trying to get "a little more" out of them, not worth it. Thankd for reading and good luck guys.
05-11-2021, 11:53 PM | #2 |
Mine didn't start loosing power until my springs hit 40k miles. Each dyno visit was great until around that point. I'm always here to help bud.
05-12-2021, 07:29 AM | #3 |
Thanks Bo, you da man!! We appreciate all your knowledge and insight..
05-13-2021, 01:20 PM | #4 |
Drives: 13' 1LE Join Date: Apr 2012
Nice, I feel ya, mine were done after 1 month LOL
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
05-13-2021, 02:58 PM | #5 |
Drives: 2010 SS L99 Join Date: Sep 2018
I am at about 18k, yeah I need to make a trip to GPI and have the next round of little goodies installed...GPI suggested the PAC .700 springs to replace the .660 BTRs
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
05-13-2021, 03:01 PM | #6 |
Wow that's a short time to wear them out, but with you spinning her up to 7900 that will do it!! I spend a lot of time with my beast above 7000 because she likes it up there and continues to make power up there, so yea I felt the difference with the new springs for certain..
05-13-2021, 07:12 PM | #7 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Well cool. I'm glad you got it done before you lost a spring. I will definitely be changing mine at or before 20k just to be safe. Did they drop the cradle to do the oil pan gasket?
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
05-13-2021, 09:12 PM | #8 | |
Glad you setup works well. I loved my ole TSP stage 3 and over 7000 was good times too!!
13' 1LE
05-14-2021, 08:42 AM | #9 |
Yes they did drop the cradle for that one... And when we put it all back together we installed new sway bar links and and bushings.. The front feels a lot more quieter and smoother now as well..
05-14-2021, 08:45 AM | #10 |
Yes sir thanks. Nothing quite sounds like an LS 3 spinning to 7000 and above when you are driving hard for short periods of time, I don't spend a lot of time up there, but enough to enjoy the pull!!
05-14-2021, 08:56 AM | #11 |
I don't spend a lot of time there either, per se, but when I want to, its there. I haven't been able to track it in quite a while, and on the street, by the time I get there in second I am around 70mph. And I don't find myself merging onto freeways much, so its just one of those things. Speeding tickets are never a good thing
05-14-2021, 07:30 PM | #12 | |
05-17-2021, 03:06 PM | #13 |
I need to swap my BTR .660 too. Life over 8000 was hard on them lol
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
05-17-2021, 05:10 PM | #14 |
There he is!! Mr lazer!! Thanks for YOUR help as well in my build sir. How ya been bro?? Well I hope. And yea I would think that life over 8000 would be a bear on the springs to say the least!!
Thread Tools | |
