JUICEDMOTORSPORTS
Old 08-03-2020, 10:08 AM   #1
Inferno dogg
Inferno dogg's Avatar
Drives: 2010 Camaro 2SS
Trans cooler sold by GPI???
Anyone use it https://gwatneyperformance.com/produ...tallation-kit/ How was the install?
Circle D 4c 3800 w/Derale trans cooler kit sold by GPI,3.90 yukon gears,Kooks long tube headers,Roto fab cold air intake, Corsa extreme 3" cat back, Dyno tuned by Baker Engineering, Heritage Grille, T4 splitter with under tray, Anvil spoiler,MRR 228 reps with Nitto NT555G2 tires 315 rear 275 fronts,BMR poly bushings,HD Diff cover from RDP,Raytech install kit and even later down the road GPI SS3 cam set up.
Inferno dogg is offline   Reply With Quote
Old 08-06-2020, 08:36 PM   #2
Scooter18155
Scooter18155's Avatar
Drives: 2010 ss/rs 6 speed manual
I haven’t but it looks like a nice unit
2010 camaro ss/rs, standard 6 speed, ls3 motor, bmr subframe connectors, jba 3” competition Exhaust, stainless works 1 7/8" headers, adm cold air intake, hurst short throw shifter, bo white ported tb, mishimoto aluminum radiator, mishimoto oil cooler.
Scooter18155 is offline   Reply With Quote
Old 08-10-2020, 08:15 AM   #3
Inferno dogg
Well I just bought it and a 3800 stall circle D from GPI yeehaa
Old 08-10-2020, 09:59 AM   #4
Scooter18155
Awesome you should update this thread with your thoughts on the trans cooler. I’m in the market for one sometime down the road
Old 08-10-2020, 11:32 AM   #5
Inferno dogg
I will definitely do that!!!
Old 08-10-2020, 09:38 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Where are you going to mount it??
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Suede Steering wheel, short throw shifter. Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, C7 GS Calipers, PAFDT Solid Cradle bushing, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs.
Old 08-10-2020, 10:02 PM   #7
Scooter18155
That is a good ? I have to consider when I get around to this.
There is two screw points just under the hood latch that can be used for mounting a cooler. I have just mounted my oil cooler there. My mishimoto oil cooler has mounting holes top and bottom. I used the top mounting to mount that cooler I might be able to get another cooler mounted to the oil cooler.
Old 08-11-2020, 07:04 AM   #8
Inferno dogg
Well I have to confess I am not mounting it. Baker engineering is doing the work and they said they would mount it and plumb it for about 100 shinnies so I couldn't refuse.I will let you know and take some pics when it is done. My guess is in front of the radiator or by the lower grill area.
Old 08-11-2020, 08:45 PM   #9
Dirtmod66
Dirtmod66's Avatar
Drives: 2010 Camaro SS
This is the cooler GPI installed when they did work on my car (SS3 Circle D 4f). So far so good. I've been up thru the Blue ridge mountains on the back roads (real curvey-up & down). The highest it read was about 185-190.
Dirtmod66 is offline   Reply With Quote
Old 08-11-2020, 09:48 PM   #10
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Location
Where an how did they mount it???
Orange Krush II
Old 08-12-2020, 06:26 AM   #11
Inferno dogg
That is great to hear!! I did that ride on my motorcycle but really want to get back there with the maro!!
Old 08-12-2020, 05:50 PM   #12
'10CamaroDude
Drives: 2010 Camaro LS
That is too small for a stand-alone cooler.
You will want to install that on the OUTPUT (to trans) side of the rad.
TRANS--->RAD--->COOLER-->TRANS
'10CamaroDude is offline   Reply With Quote
Old 08-12-2020, 07:59 PM   #13
Scooter18155
How big of a cooler would you say is big enough for a stand alone unit? I would think stand alone unit would be ideal so temp of engine coolant doesn’t affect trans temp and vice Vera. Or do you think I’m over thinking that?
Also which hose out of the radiator is the return line to the trans? Pass side or drivers side hose?
Old 08-12-2020, 08:28 PM   #14
havelegs
havelegs's Avatar
Drives: 2015 1SS RS L99
I had the one from ADM installed on my camaro. The installer bypassed the radiator and just installed it directly to the trans lines.
Did he F up?
havelegs is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
