05-27-2018, 04:23 PM | #1 |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
Drop off in power
I am wondering if this is just my car, or do they all do this...
Looking at my head up display and my analog tach, I see a redline of 6500 rpm for my ZL1. Yet, under hard acceleration in 2nd gear (I have the manual) I get a rather abrupt drop off of power at 5500 rpm. Like hitting a rev limiter. Is that what is happening? Why would there be a rev limiter 1000 RPM before redline? Does anyone else have this problem? Today is really the first time I have hammered her hard now that I have changed the oil a second time and I have changed the diff fluid.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
05-27-2018, 04:42 PM | #2 | |
Drives: 2017 ZL1 A10 Summit White Join Date: Apr 2018
Haha I made the exact same thread here this morning. My car does the exact same thing. Glad to hear it's not just my car. |
05-27-2018, 05:37 PM | #3 |
Drives: 2017 Red Hot ZL1, MXO NAV PDR Join Date: Mar 2017
There was a previous thread on this I believe, it had to do with resting your foot on the clutch pedal. Try it with your foot completely off the pedal.
05-27-2018, 05:40 PM | #4 |
Drives: 2021 Tesla Model 3 LR Join Date: May 2016
Do you leave your foot on the clutch at all when doing these pulls? Apparently there is a safety feature that is very sensitive to where if the clutch pedal is pushed in ever so slightly, it pulls power at around 5500 RPM.
While the other person experiencing the same has the A10, I know with the M6's having the light pressure on the clutch pedal from resting your foot on it between shifts can cause this issue. |
05-27-2018, 05:49 PM | #5 |
Drives: 2018 ZL1 6M, Silverado High Country Join Date: Oct 2008
Yes I had this same problem in mine and would cut out about 5000 rpm or so. Saw the thread about resting your foot on the clutch pedal. If you do this the computer will cut power around this rpm. Tried it without my foot completely off the clutch and would work like a charm and climb to 6500 or whatever rpm you want.
Previous Camaro's - 2002 Z28 6 spd manual, T tops, Sebring Silver - 2010 2SS 6 spd manual, Cyber Gray Metallic
Current Vehicles - 2018 ZL1 Red Hot 6 spd manual, Carbon Hood, Sunroof 2019 Silverado High Country, Daily Driver |
05-27-2018, 09:04 PM | #6 |
Thanks for the info. I will try this tomorrow.
I am fairly sure my left foot was resting on the clutch pedal.
