Old 06-19-2018, 12:07 AM   #1
Tran2la
Drives: 2013 Camaro with a Nova body
Question DOD delete, Keep VVT, Which oil pump (L99)
I did the DOD delete but keeping the VVT system. Will I also need to change the oil pump now that it does not have the DOD system with LOMA?
Which oil pump should I use...keep stock or buy other?
Tran2la is offline   Reply With Quote
Old 06-19-2018, 12:23 AM   #2
Dylan1214
Dylan1214's Avatar
Drives: 2014 Camaro SS L99
Keep stock. Our L99's come with a high flow pump.
MODS: GPI MAX Package ported and milled heads+(229/250,111 LSA),Johnson 2110 Lifters,BTR .660 Springs,CHE Trunnions,C5R chain,DSX Flex Fuel kit,LSA Injectors,ZL1 Fuel Pump,MAMO Ported MSD Intake manifold,BOWhite ported Throttle body,25% UDP,CAI Intake,Intake Scoop,Kooks 1 7/8 headers,Borla attak catback,Elite catch can,BMR Motor mounts,CircleD 5C 4000-4200 Torque converter,ADM trans cooler,Jannetty Trans dipstick,DSS Aluminum Driveshaft,3.91 Gears,Eaton TrueTrac,JRE Billet caps,BMR Trailing arms,BMR Toe rods,BMR rear sway bar,Pegasus Solid sub frame bushings,DSS 1,000HP Axles
Dylan1214 is offline   Reply With Quote
Old 06-19-2018, 12:59 AM   #3
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
If you keep the L99 pump expect high pressure which can lead to sucking the pan dry at extended high RPM and seal leakage.
Pro-tuned is offline   Reply With Quote
Old 06-19-2018, 07:00 AM   #4
jc615
jc615's Avatar
Drives: Camaro and Sierra
L99 you can stick with stock
jc615 is offline   Reply With Quote
Old 06-19-2018, 07:46 AM   #5
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
I've never heard of a L99 sucking a pan dry. They hold 8 quarts.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 06-19-2018, 08:09 AM   #6
Pro-tuned
Pro-tuned's Avatar
At extended high RPMs running the L99 its very possible.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Old 06-19-2018, 08:15 AM   #7
hammdo
'It's an experiment'
hammdo's Avatar
Ditto...
-Don
747 RWHP 794 RWTQ
Old 06-19-2018, 09:14 AM   #8
Abelardoo_12
Abelardoo_12's Avatar
Drives: 2011 camaro ss convertible
I used a high pressure high volume pump and never had a problem with it for over a year now
Abelardoo_12 is offline   Reply With Quote
Old 06-19-2018, 05:00 PM   #9
SSAvery
Avery@Texas-Speed.com
Drives: 2010 2SS/RS
Melling makes a L99 pump. It offers higher pressure and high volume. If you dont use a GM pump this would be a decent option. Melling part 10355
2010 2SS/RS - Texas Speed 1 7/8 Headers + 3" Off-Road X & NPP Axle-Back. Roto-Fab. Texas Speed Stage 3.2 Cam. SLP UDP. Aikman Performance Tuned 495 RWHP / 445 RWTQ on a DynoPack.
SSAvery is offline   Reply With Quote
Old 06-19-2018, 06:15 PM   #10
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
Been running my stock L99 oil pump on DoD deleted VVT heads and cam car with no issues thus far.
See sig for mods list....
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunnion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 4 Max Effort CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 06-19-2018, 07:02 PM   #11
Bandit63
Bandit63's Avatar
Drives: 2011 Camaro SS
I deleted DOD, kept VVT, running stock pump
MRR M228 Wheels, Circle D 3200 Stall, 3.91 Gear, Texas Speed VVT 3.2 Cam, CHE Rocker Arm Bushings, Texas Speed Headers, No Cats
Bandit63 is offline   Reply With Quote
Old 06-19-2018, 11:32 PM   #12
GRNFLSH
GRNFLSH's Avatar
Drives: 2015 Camaro 2SS Green Flash Edition
Stock L99 pump
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo
GPI VVT SS1 cam and CNC ported heads milled .30
BTR .660 springs, Straub solid bushing trunions
GPI rod-mod intake with I-M heat sheild
Circle D 258mm Pro single disc 3700 rpm stall converter
169F thermostat & manual fan switch
Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft
GRNFLSH is offline   Reply With Quote
Old 06-20-2018, 01:10 AM   #13
Tran2la
Thank you for all your replies. I will stick with the stock pump. I also drilled the new lifter trays with 1/2" holes for a bit more drain back to oil pan.
Old 06-20-2018, 01:45 AM   #14
Dylan1214
Dylan1214's Avatar
Drilled holes? Where/what did you drill?
