11-21-2023, 08:25 AM | #1 |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Update on my blown engine
So apparently, as many expected I spun a rod bearing and blew up the crankshaft (cracked)
Good news is the engine block is salvageable.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
11-21-2023, 08:32 AM | #2 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Whooopsy
Is cracked crank part of a spun bearing, to be expected? Or is that why it spun? |
11-21-2023, 08:40 AM | #3 |
More good news: They estimate $8500 to rebuild the engine, and another $4000 for a Stage II Cam, DOD delete and e85 tune
So I am within my budget to get the car fixed and an upgrade.
11-21-2023, 08:41 AM | #4 | |
Not sure if a rear spun rod bearing would cause the crank to crack, or if the crank cracked and caused the rear spun rod bearing. He said it doesn't look like oil or pressure was an issue. He said the oil pump looked good. Just for some reason that rear bearing got hot.
11-21-2023, 08:51 AM | #5 | |
Drives: 2011 GMC Sierra 1500 Join Date: Jun 2022
2023 LT1 Coupe M6 - Black (GBA) on Black (H1T)
Blade spoiler (5ZU), Recaro seats (AQJ), Technology pack (Y3W) LT1 PBC engine built by Shane Parker Current mileage: 310 |
11-21-2023, 08:53 AM | #6 | |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
I broke the crank in my 2016 on the Forged Engine, it broke internally and proceeded to char every bearing in the engine. When I pulled the balancer bolt oil ran out of the front of the crankshaft, not supposed to do that, Right? It sure isn't but that's modding, crazy shit happens. Sure glad your going to save some money to do some extra modding. Keep us up to date.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
11-21-2023, 08:54 AM | #7 |
I have high anxiety right now lol. Be nice to be able to drive my car again, been without it since beginning of June.
11-21-2023, 08:57 AM | #8 | |
11-21-2023, 09:06 AM | #9 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
C’mon man! I thought extra lubrication was a good thing?!?
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
11-21-2023, 09:11 AM | #10 |
Drives: 2023 2SS Convertible Join Date: May 2009
At least you are going to be down over winter and not really miss driving it. I think I have driven mine twice this month.
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold! '23 2SS Convertible -Same as above except orange. |
11-21-2023, 09:26 AM | #11 |
Drives: Chevrolet Camaro Join Date: Apr 2022
What mods did you have?
A 416 short block is near $8,000... something to think about instead of rebuilding that one.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT4 HPFP, LT4 Injectors, JMS BAP - 722WHP
11-21-2023, 09:34 AM | #12 | |
2" Speed Engineering LT (cat delete) 3" Speed Engineering X-Pipe (cat delete) MBRP 3" Axle back (getting rid of the suit case finally) DIY E85 flex fuel Stage 3 ported LT2 Intake 95mm ZR1 TB My budget is limited to about $14,000 and I'm not sure if any of the previous mods can transfer to a 416, otherwise I would agree. I think a 416 would use different heads if I am not mistaken in which case more cost with a 416. And because of the Stage 2 Cam they are going to put in: I also need a T87A unlock kit to have the trans tuned for better cam synergy.
11-21-2023, 10:01 AM | #13 |
Heads should be the same, but a limiting factor without porting them.
11-21-2023, 10:22 AM | #14 |
Drives: 70 GTX, 06 Mustang, 22 Camaro LT1 Join Date: Jan 2022
$9400 Holley Crate 6.2 an option?
2022 CAMARO LT1 COUPE AT10
