Old 07-18-2010, 01:21 PM   #1
Reeko
Drives: 69 Camaro RS Conv. 2010 Camaro SS
Help: Qrtr Panel Damage Advice.
Guys,
Some AHole ran through my fence last night and took off.
He plowed down 30yds of cedar split rail fence. Bummer enough.
But a post hit the top edge of my quarter panel. Pics attached.
From the looks of it, it creased the topline pretty good, but it also created a bulge.
Can this be repaired easily?
I don't see where the panel ends around the door frame. Should I push for repairs to replace the panel?
Should I insist on dealer repairs or go to a body shop.
Any advice is greatly appreciated.
I am way bummed. The car is only 4 months old, 4500 miles.
Reeko is offline   Reply With Quote
Old 07-18-2010, 01:25 PM   #2
Reeko
Also, pics of the fence he took out.
Old 07-18-2010, 01:35 PM   #3
2LTRS
Detailing Connoisseur
2LTRS's Avatar
Drives: 2010 Rally Yellow 2LT RS
Yikes! That sucks. I would get the panel replaced. IMO - No amount of pulling, welding, filling, bondo ect. will get that back to 100% perfect. Just re-manipulating the metal will require a re-paint anyways, you may as well have them replace the panel.
2LTRS is offline   Reply With Quote
Old 07-18-2010, 02:10 PM   #4
Reeko
Dealer or Body Shop?
Old 07-18-2010, 03:52 PM   #5
Mr Twisty
Mr Twisty's Avatar
Insurance won't pay for new 1/4 panel on a small dent. Depending on your deductible you may want to fix it on your dime.
-- Benjamin Franklin
Mr Twisty is online now   Reply With Quote
Old 07-18-2010, 04:15 PM   #6
Mr Twisty
Mr Twisty's Avatar
Either... Get a few estimates, ask about lifetime warranty.
Old 07-19-2010, 09:25 AM   #7
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
paintless dent removal can get all of that out without a trace. As long as the paint didnt crack, the damage is in an area that is easy for PDR to get to. I d look into it. I wouldnt get the quarter panel replaced unless i really had to.
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 07-19-2010, 09:55 AM   #8
Dion_1969
Dion_1969's Avatar
Drives: ABM 2SS/RS LS3
Send a message via Yahoo to Dion_1969
Here is what had to be done to mine to fix a small dent in the gills. I had the dealer body shop fix it but had numerous problems - scratched back window then chipped paint around the window after replacement..but the end product look perfect. They said this was the only way to insure it looked new. They cut it out and welded in a new one.
Those who fail to learn from history are condemned to repeat it- George Santayana
Dion_1969 is offline   Reply With Quote
Old 07-19-2010, 10:39 AM   #9
Reeko
PDR can't fix this.
1)The paint cracked pretty bad.
2) It is not just a dent, but a bulge in a complex curve, right where the normal edge would be. It raised a small part about 1/2 inch.
I think they can get at the inside, so they might be able to pound it out. Definately gonna have to re-paint.
GM bulletin on Perceived Paint Mismatch on Door and Quarter Panel Paint Appearance Tran Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 53 07-17-2013 01:16 PM
GM bulletin on Perceived Paint Mismatch on Door and Quarter Panel Paint Appearance Tran 5th Gen Camaro SS LS LT General Discussions 114 04-16-2012 03:04 PM
Understanding Paint Correction-The Nitty-Gritty Mr CLuTcH Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 29 03-02-2012 03:51 AM
Damage on a Factory Order...Advice? B-Lo Camaro 5th Gen Camaro SS LS LT General Discussions 30 03-10-2010 08:10 PM
