04-13-2022, 12:37 PM | #1 |
Drives: 2012 camaro ss convertible Join Date: Dec 2021
spare tire
has anyone put a spare dognut spare tire ,I have a 2012 convertible and would like to put a spare in truck,due to the fact it a vert,I already loose half the space,anyone know if there is a spare dougnut tha fits from possibly a nother make,, thanks
04-14-2022, 02:30 PM | #2 |
Drives: 2012 SS Join Date: Dec 2021
2012 Camaro SS
04-14-2022, 03:55 PM | #3 |
Drives: 2010 Camaro SS/RS Black Join Date: Aug 2011
Spare tire
i was looking at this also. There is a place called Modern Spare.
https://modernspare.com/product/2010...ncluding-z-28/ |
04-15-2022, 07:35 AM | #4 |
spare tire
thanks,boy it sure sucks that it gonna cost about a grand to get one sent to canada,sure wish there was something cheaper,I`ll look into it,thanks again
04-15-2022, 01:08 PM | #5 |
I believe someone on here used a donut from, I think, an X5 that fits. when I looked for one, the cost of a used one of those was pretty much the same as the website I quoted.
2012 Camaro SS
04-15-2022, 02:29 PM | #6 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
It only has to fit over the 4 piston Brembo's on the front so my suggestion is to see if the Caddy ATS came with a spare tire.
They came with the 4 piston Brembo's on the front that the Gen 6 Camaro has. BTW I say only the front because you never put a donut on the drive wheels as you will lunch your posi. My suggestion is just buy an CAA membership for 10 years
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
04-17-2022, 07:05 AM | #7 |
spare
My caddy ats doesn`t come with one either,funny, wrecking yards don`t track them either,
04-17-2022, 02:27 PM | #8 | |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
And you don't need a distance pad to avoid the brake caliper.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
04-19-2022, 06:47 AM | #9 |
any idea what year x5,also, can you give me the specs to the tire ,thanks...
04-21-2022, 06:32 AM | #10 |
waiting at the tree
I think the X5 is/was new for 2020
Glad there is a solution for people that want one.
04-21-2022, 12:31 PM | #11 | |
I think the 155/90 R18 But I'll check it out for sure.
04-22-2022, 07:27 AM | #12 |
thanks,I ended up ordering a rim and tire from performance,should get for next week,tire is good for 80,000 so it won`t need replacing,now to get a jack,will post what I got so others know
05-16-2022, 07:34 AM | #13 |
spare
I got the spare,got a jack from princess auto,the rim fits car and clear everything,tools in next to battery and opened jack enough to fit between seat and wheel cover since it is now raised up,I`m all set if I need a spare,thanks to everyone that helped,maybe this will help someone else
05-16-2022, 04:46 PM | #14 |
Drives: 2011 CAMARO R/S LT2 Join Date: Feb 2020
It took me 2 years to find the spare tire. Found it on a e bay site called Auto Pharmacy who had 1 in Texas. So it cost $330 delivered to my door with exchange and duty. But want i had found out after talking with MANY salvage yards is a 2011-2017 caprice has the same donut spare and some years of BMW models. Hope this helps with anyone looking.
