Old 06-07-2013, 07:50 PM   #1
Jbakovich
Drives: 2011 Black LS
Best show and go lisense plate holder?
I'm gonna buy one soon and wanted to know what the best one is. I don't wanna order some shit that's gonna break or fall off. Thank you. Also how is installation? Easy quick.
Jbakovich is offline   Reply With Quote
Old 06-07-2013, 08:35 PM   #2
treasurespast
Drives: 2011 Camaro 2SS RS Convertible
Speaking of license plate holders, since my new (used) Camaro came from a rear tag state, and I'm I a front and rear tag state, it doesn't have a front tag holder at all. Do I buy a front tag bracket from GM, and how are they installed? I'm guessing I have to get the drill out. :(
2011 2SS RS Convertible
treasurespast is offline   Reply With Quote
Old 06-07-2013, 08:50 PM   #3
My45thAnniversaryCamaro
My45thAnniversaryCamaro's Avatar
Drives: 45th Anniversary
Don't put it on unless you have to
45th Anniversary
MRT v2.0
CAI
My45thAnniversaryCamaro is offline   Reply With Quote
Old 06-07-2013, 08:54 PM   #4
batman53201
Account not blocked
batman53201's Avatar
Drives: The Batmobile
if you do a search on here, someone makes a bracket that you wont have to drill holes in your bumper
batman53201 is offline   Reply With Quote
Old 06-07-2013, 09:20 PM   #5
Blue-J
Blue-J's Avatar
Drives: 2013 2LT HWSE
I just installed one without drilling holes.
You might check out: http://jacfab.com/
Blue-J is offline   Reply With Quote
Old 06-07-2013, 09:27 PM   #6
JustRaf
YOU.ONLY.LIVE.ONCE
JustRaf's Avatar
Drives: Camaro 2LT/RS 2013
I just purchased a jacfab!! My ride is a very hot item right now!! Pulled over here and there.
JustRaf is offline   Reply With Quote
Old 06-07-2013, 10:38 PM   #7
snymat68
snymat68's Avatar
Drives: 2013 Blue Ray 1LS M6
I would hate living in a state that required front plates. They look like an ugly zit on a beautiful car. I know there's not much you guys can do about it though. Sucks.
snymat68 is offline   Reply With Quote
Old 06-08-2013, 03:32 AM   #8
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
JacFab
I have the JacFab that uses two existing bolts under the front valance.
It is bent to follow the contour of the front end.
It does not shake at high speeds as shown on their video.
Easy on and off, 1 minute. My car is lowered one inch and on steep angles it scrapes the bottom of the plate.
Better than the body and a good curb stop indicator.
SS PANTHER is offline   Reply With Quote
Old 06-08-2013, 06:59 AM   #9
atma
disco kryptonite
atma's Avatar
Drives: 2012 2SS/RS LS3
www.eliminatorbracket.com
atma is offline   Reply With Quote
Old 06-08-2013, 07:51 AM   #10
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
I have the show and go plate holder. I I'd not want to screw it in to my bumper, so I actually made a bracket that mounts up to one of the bumper bolts and then I mounted the show and go to that. I sprayed plastidip on the piece I made to keep it from scratching my car. Here's a couple of pics.
45thCamaro is offline   Reply With Quote
Old 06-08-2013, 08:04 AM   #11
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
my stow and show is a little less pronounced and I just mounted it with the motor in the relief in the lower bumpers bolt area and screwed it right to the bumper which is plastic, ( you see the motor sticks up not down and there fore mounting it flat is impossible unless you have a relief area for the motor to stick up) I t comes with plumbing strap in case people really want it straighter or if you have a splitter lip etc.
I wired mine right to the poitive terminal on the battery terminal to jump the car in the engine area, and grounded to the car by the same terminal....easy breasy .
Also i rarely use it except to be in a show or show it off, i have it at a slight back angle and it has pads to keep it form rubbing the paint. And mine matches the angle of the front and totally retracts under the car with only about 1/4 to 1/2 inches showing of the track. Durability.....Scrape mine damn near every day on my angled driveway have had no problem, but the plae it is mounted is not the most attractive..just most convienient.
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr, Powermaster xs 9509 starter, BMR strut brace,trailing arms, toes, bushings, Crossfire wheels & extreme contacts, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 06-08-2013, 08:51 AM   #12
Blue-J
Blue-J's Avatar
Not sure if the following was covered. One is manual and the other remote.
http://www.rpidesigns.com/shop/item.aspx?itemid=1672
http://www.rpidesigns.com/shop/item.aspx?itemid=1716
Not sure about ease of installation.
Good luck.
Old 06-08-2013, 09:29 AM   #13
heRS
Raised by Wolves
heRS's Avatar
Drives: IBM 2010 2LT RS M6
I have a buddy with a steel fab shop and he made this one for me - it attaches to the 2 bolts that hold the bumper on underneath. It was FREE so I'm not complaining one bit.
Tori
Old 06-09-2013, 12:25 AM   #14
45thCamaro
45thCamaro's Avatar
Perfect. That's what I wanted but didn't have the metal to make it.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
