04-21-2021, 11:08 AM | #1 |
Drives: '23 LT1 A10 Join Date: Oct 2015
FS: One ported TB and one stock TB
#### BOTH ARE NOW SOLD THANK YOU ####
Off of my 2015 SS. STOCK TB HAS BEEN SOLD Ported with rod mod - bought this a few years ago on here and was told it was a Bo White port stage 2. $210 shipped Link to pics: https://imgur.com/a/sng8hkE Stock TB $150 shipped Link to pics: https://imgur.com/a/9JC5xMY Please note that I was having TB sensor issues, I swapped the sensor from a new TB to the ported one but still experienced issues. I installed another stock TB on the car and it was fine. I cannot say for sure if the TB sensors on both of these are in perfect working order or not. I did not swap them back to see if my issue came back or not, so please understand that. Please PM me if you have questions or want to buy this. I don't check this thread daily.
24 LT1 M6 Sharkskin Metallic
04-21-2021, 11:20 AM | #2 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
You opened the blade for the pic?
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
04-21-2021, 11:51 AM | #3 |
For the ported one? No, that is the way it has always been.
FYI here is the link to the post from when I bought it. It has a pic in there so you can see it as well: https://www.camaro5.com/forums/showthread.php?t=433615 |
04-23-2021, 01:28 PM | #4 |
The ported one is one of mine.
04-23-2021, 03:27 PM | #5 |
Thanks. I've enjoyed it but sold my car last month and stuck a new stock TB on it. It served me well.
Sent from my motorola one 5G ace using Tapatalk
04-23-2021, 06:01 PM | #6 |
Drives: 1971 Camaro Z-28 Join Date: Sep 2015
Tb
04-24-2021, 01:30 AM | #7 |
Banned
Drives: 2010 LS Join Date: Feb 2021
The blade is at the off position, and is closed. Just because it is on that angle,
does not mean it is open. It is not open, and in fact, will open when at idle. Not all Throttle plates are straight up and down when closed, they're always at an angle. This is a V6 one, and it's not straight up and down: That's the way they are. |
04-24-2021, 06:36 AM | #8 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
It's just an optical illusion between the porting and angle of the picture. It looks fine.
04-24-2021, 11:27 AM | #9 |
Here is a video showing me push the blade to the most closed position in case there are any questions
https://youtu.be/6una_MVND0g The stock throttle body blade sits at the same position as this ported one. It is expected to be at that position.
04-24-2021, 11:32 AM | #10 |
Banned
Man-powered operation, ha ha ha. I expected to see it on the car...
04-24-2021, 01:07 PM | #11 | |
04-29-2021, 03:41 PM | #12 |
Bump
Sent from my Pixel 4a (5G) using Tapatalk
04-30-2021, 03:50 PM | #13 |
The blade at rest is at an angle by design. When you start the car it self adjusts to regulate the idle air flow.
05-07-2021, 09:43 AM | #14 |
Still have the ported TB. Open to offers.
