11-28-2013, 01:18 PM | #1 |
Drives: 2011 Camaro 2SS Join Date: Oct 2011
Help! Why are my bushings behaving like this?
So, I go to do my annual greasing of my trailing arms and toe rods from PFADT. Not sure if I'm doing something wrong (Kind of hard to imagine), somethings wrong with the bushings or install, or if I'm just over thinking.
Anyways, my normal way of greasing anything is pump the grease 'till fresh grease oozes out. Wipe the oozed grease away and call it a day. How could that be done wrong, right? lol. I go to pump up this one bushing and I get some ooze but at the same time, the rubber flange is pressing out. So I pump more thinking maybe it will "pop", release grease and sit back down. Just keeps coming out and out with no grease releasing! For fear of blowing something up I stop. Then It bothered me that half the flange is now sticking out and cockeyed so I loosen the bolt and retorque it down which took the tension off the rubber and allowed it to go back to place. I go to another bushing and the same thing starts happening. This time once I saw the rubber moving I just stopped pumping the grease in and left it alone. So basically; Is this normal? If not, should I be concerned and do anything about it? Is greasing until the flange starts squeezing out sufficient? Am I stupid or something? I feel like this is such a silly thing.
11-29-2013, 09:29 AM | #2 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Bump. I'd like to know too because I'm considering buying these!
11-29-2013, 12:41 PM | #3 |
Drives: 14 1LE Join Date: Mar 2013
Its pushing it out because of hydralic force...the grease has no where to vent other than to force the bushing out of the way. I would loosen the bolts each time you grease the bushing. Also, with the bushing being sealed that well you probably dont have to grease very often, grease can't escape and dirt cant get in.
LMS Engineering
11-29-2013, 12:48 PM | #4 | |
Best regards, Tyler 888-308-6007 |
