09-24-2014, 12:00 PM | #1 |
Waterboy2B98
Drives: 11 2SS M6. Join Date: Feb 2012
Any advice for a new drag radial owner??
I just ordered a new set of Nittos Nt05rs and 18" rims. My car makes 475 RWHP. I have 1000HP axles, BRM trailing arms, toe rods, bushing upgrades, and a posi mod with 3.91 gears.
I have ran my car at the track when it was stock, but not since I did the upgrades, and not on DRs. My question is that what pressure is the best for the track, I live in South Louisiana and its 65 degrees. And does anyone use the competitive mode for launching? I have never used it before, but now that I got new axles and better tires, I was wanting to give it a shot? Just not sure if the higher RPM launch will break spider gears or melt stock cluch? My car fund is depleted for now, and would hate to have to trailer it home! |
09-24-2014, 02:40 PM | #2 |
Drives: ZL1 Camaro Join Date: Feb 2009
I run mine at 18 psi (warm)
09-24-2014, 03:06 PM | #3 |
Waterboy2B98
Heat them up good the first pass and then knock the rocks off after that?? Avoid the water box?? Thats my plan, just wondering if its correct??
09-24-2014, 09:11 PM | #4 |
Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
Avoid the water box and back in if your not running skinnies up front. Start at 18 and move up or down depending on traction.
09-24-2014, 11:39 PM | #5 |
Drives: 2011camaro SS Join Date: Nov 2012
If you baby your clutch you will be ok for now. But when you start to get more aggressive and try leaving at high rpms and slipping the clutch, it won't like it at all. You will need a clutch later.
09-25-2014, 09:58 AM | #6 |
Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
add a line lock. NT05R's need to get HOT or they won't stick.
10-16-2014, 02:09 PM | #7 |
Fight Crime, Drive Armed
Drives: '14 2SS Yelo Maro, HD collection Join Date: Jun 2013
...but they will be easy on the stock clutch.
Bring back Sunoco 260 to the local station. Some folks STILL drive L-88s and need the good gas.
10-17-2014, 05:59 PM | #8 |
OP, Even with the good axles, still watch the launches. My diff went before my stock axles.
Strong diff options are very expensive.
"Democracy Dies in Darkness" |
10-17-2014, 10:03 PM | #9 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
Stock driveshaft and clutch?
10-17-2014, 10:04 PM | #10 | |
In The Circle
10-17-2014, 10:09 PM | #11 |
Slowhawk Built
Drives: 2010 Supercharged SS Join Date: Apr 2014
This^
9.21 @ 149 Slowhawk Performance
Thread Tools | |
