05-25-2018, 09:35 AM | #1 |
Drives: 2013 Camaro LS Join Date: Nov 2016
How to clean your CAI intake
Just curious what tips/procedures you might have for cleaning a non oiled intake. Noticed mine looks like it could use some cleaning.
05-25-2018, 10:10 AM | #2 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
What parts are you cleaning?
If it's the filter, you can shake it out. But if it's a dry filter... you just replace the filter if it's dirty.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
05-25-2018, 11:24 AM | #3 | |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
if its a dry filter (no oil) you can clean it in dawn soap/water, let it dry, and then install for an oiled filter you must use a dedicated filter cleaner, dawn/water, or a degreaser to remove the oil and dirt. once you have cleaned it set it to dry and once dry you apply clean air filter oil before installing it. don't over use the oil though if it is a stock paper panel filter (stock intake) then you just chuck those and replace with another
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
05-25-2018, 01:43 PM | #4 |
I just prefer to replace dry filters over cleaning them. Oiled filters help trap dust with the oil, dry filters use a tighter weave. I always feel like water and soap mess with the weave. I'll shake it out, give a little vacuum, but if it's dirty enough that I think it needs to be fully cleaned, I'll replace my dry filters for peace of mind.
05-29-2018, 10:27 PM | #5 |
Drives: 2010 Join Date: Mar 2015
I use a mild detergent and water to clean my dry filter. Don't blow the filter using an air compressor as it can create holes.
05-30-2018, 08:57 AM | #6 | |
If you were to clean a dry intake the way you would an oiled intake would you be putting the dry intake in any harm? |
05-30-2018, 09:00 AM | #7 | |
05-30-2018, 09:11 AM | #8 |
Got a picture of your intake?
I have a CAI inc. brand intake on the Camaro, I clean and oil that one as needed. I have an AEM Dry Filter on my supercharger of my Monte Carlo, it's a dry filter, but I just replace it if it is that noticeably dirty, because it's leading to a blower and it's only $50.
05-31-2018, 09:10 AM | #9 |
Drives: 2012 Camaro Convertible Join Date: Jun 2017
i was lucky, I bought my CAI system used the previous owner bought a second filter, so when i'm cleaning, drying and oiling I've got a second so i can just rotate.
Means I'll never need to buy a replacement filter either unless I find a way to damage them. |
Thread Tools | |
