Old 06-18-2018, 06:34 PM   #1
andrewpeanut
Drives: 2015 Chevy Camaro 1SS
6 piston Brake upgrade
Hi all
could someone who has done this swap before help me confirm parts?
'15 Z06 W/O Carbon Ceramic Calipers
1722646
1722645
'15 ZL1 Backing Plates
20944532
20944531
'15 ZL1 Lines
Rotors
are off of 15 ZL1 or what year CTS-V?
I was guessing 15 but im just trying to be sure
and of course pads for a 15 Z06 to match
is there anything else im missing?
all input is gratefully appreciated.
andrewpeanut is offline   Reply With Quote
Old 06-18-2018, 08:22 PM   #2
swampcritter
Drives: 2014 Camaro LS / 13 zl1
I think you need the axle nuts and the caliper bolts as they are TTY bolts.
swampcritter is offline   Reply With Quote
Old 06-18-2018, 09:04 PM   #3
608RS
608RS's Avatar
Drives: 2015 2ss
here is what i have so far, i don't know if this is 100% everything needed for front 6-pot conversion:
Mfg + Part Number Description
ACDelco 177-1146 passenger side rotor
ACDelco 177-1145 driver side rotor
ACDelco 172-2488 passenger caliper
ACDelco 172-2487 driver caliper
ACDelco 20944532 Driver Dust Plate (Backing Plate)
ACDelco 20944531 Passenger Dust Plate (Backing Plate)
ACDelco 18K2108X brake caliper hardware kit
Good ridge 12227 stainless brake lines (zl1 calipers)
2015 Camaro 2ss, NicKey Performance built/tuned
608RS is offline   Reply With Quote
Old 06-19-2018, 12:58 PM   #4
andrewpeanut
I could see changing caliper mounting bolts
but theres no axle nut to change up front?
Old 06-19-2018, 01:01 PM   #5
andrewpeanut
so that's ZL1 rotors and CTS-V(09-15) calipers? correct?
hardware kit ok makes sense
