10-19-2016, 07:22 PM | #1 |
Drives: 2015 AGM 1LT Join Date: Jul 2015
Brake Conversion questions
Hey guys!
I'm looking to pick up a set of ZL1 calipers, rotors, and pads to fit on my LT. From my understanding this should be a bolt on upgrade with the only major work being to trim the dust shields. I know the back ones will have to be cut, but will the fronts? I couldn't find any info on 6 pot ZL1 calipers going on a V6 to confirm this or not. I want to make the guess that they would since they are quite a bit larger than even the 4 piston ones. If I'm missing anything please let me know. Thanks! |
10-19-2016, 07:38 PM | #2 |
Also, does anyone know if these will fit behind the MRR 228 wheels? They are 20x10 35mm offset on the fronts 20x11 43mm offset on the rear
10-19-2016, 08:06 PM | #3 |
Drives: 2010 2SS/RS Join Date: Dec 2009
This makes get help
http://www.camaro5.com/forums/showthread.php?t=461860 An I beleive there is minor trimming required for the rears.
Orange Krush II
