Old 02-18-2019, 11:12 PM   #1
krusher
krusher's Avatar
Drives: 2010 Camaro SS/RS CGM
New look for my engine bay.
Had a rear main, and thought it would be a good time to finish cleaning my engine bay while I took the engine out. getting close to being done.
krusher is offline   Reply With Quote
Old 02-19-2019, 10:01 AM   #2
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
looks good but the waterpump is killing your flow (no pun intended)
the routing of the brakelines through the cowl is awesome. ive never seen that before.
also, are the 2 holes in your wheel wells for the choo choos?
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 02-19-2019, 11:20 AM   #3
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2014 Camaro 1SS RS SIM
Damn, valve cover and intake delete for weight savings? That's next level! :P
2014 SS - BTR Stg 2 Cammed L99 1SS/RS FBO - "AleSSandra"
SSEssence is offline   Reply With Quote
Old 02-19-2019, 09:47 PM   #4
InFiD3ViL
InFiD3ViL's Avatar
Damn! Looking good!
Did you respray under there or did you just keep your nearly 10 year old car immaculately clean?
Edit: Stupid question, duh. My CGM doesn't look like that under the hood. Derp.
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP long tube headers (W/Catless Off-road Pipes), FlowMaster Outlaw axle back/X-Pipe, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160º thermostat - Megan Racing adjustable coilovers (lowered 1.75"), Firestone Firehawk Indy 500s - Tuned by Ryan @ GPI via HP Tuners
Old 02-19-2019, 11:06 PM   #5
krusher
krusher's Avatar
I also got black headers. and other parts thats why I choose a black wrinkle finish. Hindsight I did it to hide a not so perfect sanding job. I am changing the color of headers and throttle body, but I'm in the middle of a move, a new kid, and trying to hurry and finish the car (very busy to say the least).
The two holes are for my strut bar and that is going to be a different color eventually too. I got to just get it back together as time and budget are pretty much it for right now.
Old 02-19-2019, 11:13 PM   #6
krusher
krusher's Avatar
Damn! Looking good!
Not a dumb question, it was CGM PRIMER and not cleared. later I cleared it when I installed my cam. years ago I relocated the fuse box and ABS.
I just wanted something to show off all that I have done as CGM is so dark its kinda hard to see what I have done. Here are some old pictures from what it was originally this year.
[ATTACH]Name:  old.jpg
Size:  173.7 KB[/ATTACH]
Old 02-20-2019, 12:42 PM   #7
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
Looks amazing! That takes a ton of work to do something this nice. I wish I had the time and patience to do something like that.
PepeLePew is offline   Reply With Quote
Old 02-20-2019, 06:56 PM   #8
Motorboy8769
Drives: 2015 2ss
Where did you mount your coil packs?
Motorboy8769 is offline   Reply With Quote
Old 02-20-2019, 07:13 PM   #9
PFL
PFL's Avatar
Drives: Camaro SS
[ATTACH]Attachment 975822[/ATTACH]
Resevoir power steering realocated?
PFL is offline   Reply With Quote
Old 02-20-2019, 08:15 PM   #10
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Attachment 975642
Sweet!
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 02-20-2019, 08:20 PM   #11
Jayjellyfish212
Drives: 2014 1LE
Old 02-20-2019, 08:25 PM   #12
Jayjellyfish212
Drives: 2014 1LE
I’m in the same boat. Each winter I been doing a section to clean up. This year I did the ABS module relocation. Gotta paint the passenger side tower in spring time.
What strut tower bar do you have? I been looking for something aftermarket..
Old 02-20-2019, 08:51 PM   #13
PepeLePew
PepeLePew's Avatar
Impressive!!! I’m taking notes!
Old 02-20-2019, 08:58 PM   #14
Motorboy8769
Drives: 2015 2ss
How are y’all removing the clutter on the passenger side is there a forum link?
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
