Old 04-04-2019, 10:59 AM   #1
Motorboy8769
Drives: 2015 2ss
Idle recovery
I put an aluminum flywheel and lighter clutch in the car and now the idle after rev will drop to 300 ish and then surge a couple times then back to 850. Sometimes it stalls. I have read to adjust airflow I am just not sure which airflow table to adjust there is several. I am using hp tuners.
I am afraid of this thing stalling as I am staging the car and costing the race.
Thanks in advance
Motorboy8769 is offline   Reply With Quote
Old 04-04-2019, 12:17 PM   #2
xc_SS/RS
Drives: 2010 Camaro SS/RS
Adjust your throttle follower in neutral and park to have a little higher values than stock and keep increasing until you've got it how you want it
Also, there's a o2 sensor setting for LTFT idle cells that when switched off (set speed requirements to 255/256) help reduce the idle bounce when you shift to neutral at speeds
What did you go with btw?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 04-04-2019, 07:09 PM   #3
Motorboy8769
Drives: 2015 2ss
I’ll take a look at those. It’s a stick car so not sure if that changes the park neutral thing.
The car has a jerico 4 speed a ram aluminum flywheel with segmented steel inserts and a McLeod soft loc
Old 04-05-2019, 07:37 AM   #4
xc_SS/RS
Originally Posted by Motorboy8769 View Post
Iíll take a look at those. Itís a stick car so not sure if that changes the park neutral thing.
I just copy/paste the values from neutral to park since I think they're the same on the tune lol probably does nothing but it looks better on the tune
2010 2SS/RS
Old 04-18-2019, 02:49 PM   #5
Motorboy8769
Drives: 2015 2ss
So my ltft stuff is all disabled I think but I did have some questions as to what these should be set to...
Old 07-28-2019, 12:47 AM   #6
Smoky10
Drives: 2010 Camaro 2SS
Did you find a fix for this problem?
Smoky10 is offline   Reply With Quote
Old 07-28-2019, 01:23 AM   #7
Motorboy8769
Drives: 2015 2ss
I have not messed with it for a while I am deployed right now. I did however hear about an update that gives a new option to change that may help. I’m probably going to be doing som more work and possibly another dyno tune this winter so hoping I can get it fixed then
Old 07-28-2019, 06:32 AM   #8
Smoky10
Where are you deployed to? I’m also deployed with RED HORSE right now
Old 07-28-2019, 07:13 AM   #9
Motorboy8769
Drives: 2015 2ss
KAF currently in Afghanistan
Old 07-28-2019, 07:39 AM   #10
Smoky10
Cool. One of my Airman is at BAF.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
