06-20-2019, 05:47 PM | #1 |
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14 Join Date: Nov 2014
Still spinning
Went back to the track last Sunday with the SJM linelock installed and I can not stop spinning. I’m probably as close to a perfect light as possible but I’m spinning past the 60’ what’s my problem?
02 Stepside Silverado
05 ZX-10 13 1LE 14 Nightrod Special |
06-20-2019, 05:49 PM | #2 |
Drives: 2010 SS L99 Join Date: Sep 2018
Whats your wheel and tire combo again Nic? Forget what you run. What was your 60'?
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
06-20-2019, 10:24 PM | #3 |
315/30/20 rears 285/30/20 fronts on the stock 1le rims with 35psi. I’m probably running a 2 to 3 60 foot they said my slip didn’t print and only had time for one run
06-20-2019, 10:47 PM | #4 | |
Lighter, more sidewall, go with a good Mickey Thompson and lower your tire pressure down from 35psi <--- to about 25 psi to start with, and I bet your 60' drops drastically.
06-21-2019, 06:27 AM | #5 |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: Dec 2015
On stock tires I had to drop psi down to 28-30 psi, with 60’ around 1.90 if I rolled into the throttle with finesse to reduce the spin. Switched to 17” M/T ET Streets and dropped my 60’ down to 1.60.
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo GPI VVT SS1 cam and CNC ported heads milled .30 BTR .660 springs, Straub solid bushing trunions GPI rod-mod intake with I-M heat sheild Circle D 258mm Pro single disc 3700 rpm stall converter 169F thermostat & manual fan switch Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft |
06-22-2019, 09:09 AM | #6 | |
Acammer gave me a technique to try, he said flash up the rpms as I leave the line instead of holding them at 4500 and slipping the clutch. So I’m going to try that. Are you on Instagram?
