Old 09-23-2018, 02:27 PM   #1
Ashn_G_1LE
Ashn_G_1LE's Avatar
Drives: Camaro 2SS/RS 1LE
Help with E85 *questions*
Hey guys! So I’m doing a full cam kit from VR soon, Johnson lifters and ati pulley. I have arh long tubes, and a rotofab intake. I wanna do the E85 flex fuel when I tune so I know typically you should upgrade fuel pump and injectors when you run e85. My car is a 1le so I believe it has bigger fuel pump and injectors from Zl1. Do I still needa upgrade?
Work hard, play harder
Ashn_G_1LE is offline   Reply With Quote
Old 09-23-2018, 03:12 PM   #2
Bo White
Bo White's Avatar
Correct. 1LE has the ZL1 pump. Just get some injectors
Old 09-23-2018, 03:54 PM   #3
Arch-City
Drives: 2015 Camaro 1LE
What Bo said, you car should have the ZL1 pump but you will need to get atleast the ZL1 injectors. The 1LE's do not have ZL1 injectors from the factory.
Arch-City is offline   Reply With Quote
Old 09-23-2018, 05:56 PM   #4
Ashn_G_1LE
Ashn_G_1LE's Avatar
Thanks guys !
Old 09-23-2018, 06:05 PM   #5
Ashn_G_1LE
Ashn_G_1LE's Avatar
Any recommendations on injectors size with that set up?
Old 09-23-2018, 06:34 PM   #6
Bo White
Bo White's Avatar
ZL1s will do until a stroker
Old 11-05-2018, 01:48 PM   #7
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
FAWK how i wish i didnt have to drop the rear cradle to do E85 on my car! I have the CTS-V injectors and the FlexFuel sensor ready to go!
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 11-05-2018, 02:12 PM   #8
Roader
Drives: Camaro
why would you? just cut the access panel
Roader is offline   Reply With Quote
Old 11-05-2018, 02:22 PM   #9
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
You might need the ZL1 Fuel Pump Control Module or if your tuner can reprogram your current one. ZL1 pump will operate as a SS pump with SS FPCM
Orange Krush II
Old 11-05-2018, 02:55 PM   #10
13SSCamaro
13SSCamaro's Avatar
Drives: 2013 Camaro SS
No need for the ZL1 fuel pump control Module. I just did this upgrade. DSS flex fuel kit, 850 injectors, ZL1 fuel pump and a 93 and E-85 tune
2013 SS M6, TSP Stage 3 231/246 cam kit, TSP Trunion upgrade, Cold Air Inductions CAI, VMAX PTB, TSP 1 7/8 Long tube headers and high flow cats, Corsa Xtreme ZL1 Catback exhaust, Elite E2-X Catch can, Trick Flow Gen-X 255 heads milled 0.025 and valve job, GPI rod mod and ported intake, ID850 injectors,ZL1 fuel pump, Flex sensor and E-85, Mantic 9000 and 1LE 3.91 diff 512rwhp/462rwtq
13SSCamaro is offline   Reply With Quote
Old 11-05-2018, 03:24 PM   #11
sixty9fordkiller
You're such a dirty whore. lmao
Bone Stock
Old 11-05-2018, 03:30 PM   #12
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
Yup all you need is injectors. I went with zl1 injectors and also got an ADM FPCM. 1le owners are lucky to have a zl1 pump stock lol
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 11-05-2018, 03:41 PM   #13
DSX Tuning
Drives: 2019 Corvette ZR1
I have a combo deal for flex fuel injectors and a kit for $475.25. They are factory 50lb flex fuel injectors, and I have the full characterization data for them.
DSX Tuning is offline   Reply With Quote
Old 11-05-2018, 03:50 PM   #14
Bo White
Bo White's Avatar
For comparison ZL1 injectors are 52lb
