10-10-2018, 09:52 PM | #1 |
Drives: 2013 Camaro ZL1 & 1979 10.5 Camaro Join Date: Jul 2016
2013 Driver Seat Upholstery Issue
Hello There
I have a permanent stain appearing issue with my driver's seat(part you sit on). I had it cleaned and it didn't come out. Further inspection, it appears it is burned/melted. Is it even possible to have it re-upholstered? Or am I better off buying a new seat? If so, what is the going rate and do you have suggestions on where I can find one? Thanks, Ed |
10-14-2018, 08:53 PM | #2 |
Drives: 15 ZL1, 61 Vette, 32 Ford Roadster Join Date: Jun 2014
You can just buy a new seat cover from GM, #23161545. Multiple sites online or from you local Chevy dealer. If you can't install it find a good upholstery shop near you to do it.
10-16-2018, 11:26 AM | #3 |
Drives: 2013 VR ZL1, M6 Join Date: Nov 2017
subd
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
10-17-2018, 08:52 AM | #4 |
Drives: 2013 ZL1 M6 Join Date: Sep 2016
This is good to know. The lower bolster is starting to look worn on mine from getting in and out of the car
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP 630.35 RWTQ |
10-22-2018, 07:28 PM | #5 |
Thanks for the help on the part number.
10-23-2018, 04:52 AM | #6 | |
Drives: 2014 Camaro LS / 13 zl1 Join Date: May 2016
seat cover replacement
10-23-2018, 06:13 AM | #7 |
I just ordered a drivers side seat bottom cover for my ZL1. My seat has two tiny holes in the suede that were repaired by the original owner... Started bothering me, even though they aren't that noticeable. The correct part# per my vin# is 23161532 just an FYI for those ordering for their ZL1.
11-06-2018, 06:49 AM | #8 | |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
These are per my VIN supplied request to gmpartsdirect. I got this back as far as front seat covers. NOTE: My car is a convertible. I do not know if the seats are different, but apparently the driver seat bottom is the same, so.....but you should verify to be sure.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
11-09-2018, 08:50 PM | #9 |
Drives: corvette z06 Join Date: Feb 2018
how does the suede inserts age compared to leather?
Are they holding up well so far in most peoples case ? |
11-20-2018, 11:54 AM | #10 | |
The suede holds up great, as long as you maintain it. I use my Adam's cockpit brush on my seats, and steering wheel about once a week to prevent matting. The steering wheel, and shift knob (with suede package), see extra wear from the abrasive contact with your skin on a daily basis. Keep that in mind.
