03-19-2011, 10:16 AM | #1 |
Drives: 2010 1SS/RS M6 Join Date: May 2010
MGW shifter + notchiness?
I'm very interested in getting the MGW shifter as I find the stock shifter absolute garbage but my problem is the nibble from 2-3. A good amount of the time I'll hit a notch about midway point between neutral and 3, which is pretty damn annoying considering every other gear is smooth.
Can anyone chime in if the MGW shifter will get rid of this problem or perhaps even make it worse? Something tells me the nibble just might be because of the sloppy stock shifter. |
03-19-2011, 10:56 AM | #2 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
I can't speak for the MGW but my Hurst short throw made no difference. The 3rd gear "notch" is an inherant problem with the Tremec 6060. Guys have tried aftermarket short throws, different fluids, etc but nothing really seems to help. GM changed out my entire transmission because of 2nd & 3rd gear issues on mine and I STILL get a slightly notchy 3rd gear shift!
I've heard that the MGW is a top shelf product and certainly a worthy upgrade to the stock shifter but there's really no guarantee that it will help the notch going into 3rd. |
03-19-2011, 11:06 AM | #3 |
Drives: 2013 IOM ZL1 Join Date: Nov 2009
Not sure what you mean by notch but the MGW wants to go from 2 to 3. It takes extra effort to go from 2 to 1. The stock shifter is garbage. I love my MGW.
03-19-2011, 11:14 AM | #4 |
Drives: black camaro, duramax, and cobalt Join Date: Mar 2010
I just installed my mgw last night, took it for a drive at 2am.. I was more than impressed! Never had to give it a second thought on what gear I was in or what gear I was going to. I got the retro ball, its feels like your part of the tranny when your shifting... downs: kinda a pita to install, but can be installed by anyone.. and a little bit of noise from tranny, but was expected using hard bushings. It comes with softer bushings to stop this but I wanted more of a direct connect to tranny... Very good product!!
03-19-2011, 12:14 PM | #5 | ||
03-19-2011, 02:48 PM | #6 | |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
I love my MGW by the way. -Mark. |
03-19-2011, 08:34 PM | #7 |
Boosted Moderator
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
03-19-2011, 08:42 PM | #8 |
It's a sickness!
Drives: '69 442 Vert Join Date: Dec 2009
With the stock shifter, do not put your hand on top of the shifter.
I found less (actually none) missed shifts at the track holding it like a pistol grip. It moves your elbow in closer to your side and changes the stroke of the shift. |
03-19-2011, 08:53 PM | #9 |
I'm not having any problems shifting, just commenting that the stock shifter is garbage and was wondering if upgrading to the MGW would have any effect on the notchiness of third. But by the looks of it, I'm gonna have to get on my dealers ass about my tranny before I upgrade to the MGW, because no doubt they'll blame the notchiness on an aftermarket shifter.
03-19-2011, 11:03 PM | #10 |
Drives: 2010 2ss Join Date: Sep 2009
I love my shifter gets better and better with time.
LPE 417 Stroker, 780 Hp, 780 Tq
Corsa Cat Back, LPE gt9 cam ARH LT Headers High flow cats Pfadt adj coilovers,Pfadt trailing arms, Pfadt Dif Bushings, Pfadt rear tie rods Hotchiss Cassis Brace, LPE 3.91 gears MGW shifter,Billetprototypes Catch Can LPE Pedals, LPE Sway bar links LPE custom ralley stripes, Paint upgrade and 4 coats of clear Lingengelter Embroidered Headrest Foose wheels, LPE Brake calipers with slotted rotors Hotchiss/LPE Strut Brace, |
03-20-2011, 07:39 AM | #11 |
you may want to change the fluid. Many people have seen the slight noise issue resolved with a fluid change.
03-20-2011, 08:21 AM | #12 |
It's a sickness!
03-20-2011, 09:46 AM | #13 |
WICKDSS
Drives: 2011 1SS/RS IOM LS3 Join Date: May 2010
I installed MGW shifter on mine as well. LOVE IT!! Haven't noticed a notchiness in 3rd gear though. Way better than the garbage stock unit.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei 11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds. |
03-27-2011, 10:42 AM | #14 |
Yogi
Drives: Cyber Gray 2SS/RS Join Date: Mar 2010
I installed my MGW Shifter yesterday. Way better than the stock shifter. On high speed shifting, sometimes 3rd or 2nd wouldnt go in right but now it goes in nice and smoothly. I received the "new design" shifter from MGW and it caused a little confusion at the end because I didnt read the revisions, but other than that, the install is pretty easy. Maybe MGW can post up pics of the new design and the changes they made to the shifter. There's a new bracket for the dust boot but I didnt know where to put it so I left it off. So far hasnt caused any problems without it.
Similar Threads | ||||
DIY Hurst Short Throw Shifter Install - Pix and Video | TAG UR IT | Camaro DIY & HOW-TO instructions & discussions | 121 | 02-26-2015 10:08 AM |
My Shifter Review – Factory vs Hurst vs MGW | caverman | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 46 | 02-02-2013 04:03 PM |
Pic's of Aftermarket Shift Knob on Stock shifter stalk | jammer174 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 3 | 12-04-2010 08:49 PM |
MTI Racing 5th Gen Camaro Shifter SALE | MTI Racing Kevin | Transmission / Driveline | 0 | 05-24-2010 08:30 AM |
MGW SHIFTER COMPLETE FIRST RUN OF 25 TO SHIP SOON...FULL SPECS AND PICS | MGW | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 59 | 12-26-2009 12:49 PM |
