06-26-2019, 02:33 PM | #1 |
Drives: 2014 LS RIP Join Date: Sep 2017
Overkill Supercharger kit, which cams
Whats the best cam combo for a supercharged 3.6 At? That will mainly be street driven.
06-27-2019, 06:56 AM | #2 |
Drives: 2012 Camaro LS V6 Join Date: Aug 2016
I believe MagnumForce has Mace cams and Overkill stage 3. Messaging him may get you some help. His build thread is one of the best on here. Though his is an LLT and yours is an LFX if that matters...
06-27-2019, 06:57 AM | #3 |
Built Not Bought
Drives: 2010 Twin Turbo LFX Join Date: Jun 2016
Only cam option is mace profile.. contact will from overkill he has them with the modded fuel lobe for forced induction
2010 Twin Turbo LFX
In Memory of my DAD Gone but never Forgotten 2014 "Built Not Bought!' Sponsors: OverKill Motorsports |
06-27-2019, 08:52 AM | #4 |
Thank you.
06-27-2019, 06:52 PM | #5 | |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
From the sidelines, thanks for this post. I had no idea this was a thing. Information by word of mouth can be tricky and I've been wondering how to get the "Overkill fuel lobe" cams since I've only seen one poster with them, figured it was a one-off.
06-28-2019, 12:52 AM | #6 |
Back4Revenge
There haven't been any successful Mace Cam Fuel Lobe Mods Added to the Supercharger Stage 1 or 2 Yet...
I chose my 6 with Pride..
06-28-2019, 08:27 AM | #7 |
06-28-2019, 05:01 PM | #8 |
Drives: 2014 LS Camaro Join Date: Jan 2019
Overkill Supercharger Kit
06-28-2019, 08:28 PM | #9 |
06-29-2019, 06:47 AM | #10 |
06-29-2019, 07:45 AM | #11 |
That’s impressive. What do you use it for? Driver only or ? Anything done to the transmission or drivetrain? Any exhaust work? I know I’ve got 20 questions. I just like to hear what these little workhorse engines can do.
06-29-2019, 10:13 AM | #12 |
Eaton Tru Trac , 3.91 gears, 1 Piece CF Drive Shaft, MBRP Catback exhaust
07-01-2019, 09:06 PM | #13 |
Drives: 2014 1LS M6 Supercharged Join Date: Feb 2011
522 RWHP is way to much for stock , What have you done to the Eng internals?? I'm at 400 RWHP, maybe a little more with my new WasteGate. I wont go any higher with a Stock Eng.
07-02-2019, 09:33 AM | #14 |
Back4Revenge
I asked will directly is there any successful Mace Cam + Fuel Lobe + Stage 2 Overkill Supercharged LLTs and there wasn't. Are you LFX?
