Old 06-12-2018, 05:47 PM   #1
Zl1dad
Drives: 2013 zl1
Bias ply rear/ radials on the front
Hello, getting mixed reviews on some Mt 28/11.5/17 in the rear and 225//45/17 radials in the front . 2013 Zl1. Track use only
Sent from my HTC 10 using Tapatalk
Zl1dad is offline   Reply With Quote
Old 06-12-2018, 10:39 PM   #2
Bo White
Bo White's Avatar
I daily on the oposite
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 06-13-2018, 10:31 AM   #3
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Radial fronts with bias rear will not track as well as a bias on front.
You can run a bias front well with either bias or radial rears.
Rhino79 is offline   Reply With Quote
Old 06-13-2018, 10:47 AM   #4
hntrgthrs
hntrgthrs's Avatar
Drives: 2015 ZL1
He's getting mixed reviews since he posted it here and we are all largely telling him not to run this combo:
https://www.camaro5.com/forums/showthread.php?t=530958
Rhino is correct. Bias in the rear with radial up front is a bad combo that is just not the proper way to do it. OP needs to get a set of skinnies up front with some frontrunners or just use a radial out back.
2015 ZL1 Coupe - Summit White | Stock (for now)
hntrgthrs is offline   Reply With Quote
Old 06-13-2018, 12:06 PM   #5
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
My car at 125MPH with bias on the back and stock tires on front damn near swapped lanes at the track. It is dangerous and espicially if you are not prepared and try to correct it.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 06-13-2018, 10:20 PM   #6
Zl1dad
Drives: 2013 zl1
That's a 10" wide on 19" rim stock front tire. I have 245 on a 17" rim. You probably had 32 psi, mine have 42psi Big difference when comparing.
Old 06-13-2018, 10:31 PM   #7
Yellow Bullet
Yellow Bullet's Avatar
Drives: 2017 Chevy Sonic RS 1.4T
Why ask a question if you will automatically argue for one side? I have yet to drag my car so I don't know but what I do know is that the smartest people when it comes to our Camaros are the people on here. Just my $00.02
2015 Camaro RS/SS SIM LS3- Sold
2017 Sonic Mosaic Black RS 1.4T
Yellow Bullet is offline   Reply With Quote
Old 06-14-2018, 06:43 AM   #8
Zl1dad
Drives: 2013 zl1
I'm not being argumentive, and yes that's y I'm asking Camaro owners this question. Why provide input when it is out of left field. You went bias in the rear and left a huge front radial on there and wonder why you got shoot out of the lane. I may be asking about a radial mix but at least it's a 8" tire not 11". I want opinions from people with experience in this. Not just everyone telling me what they hear.
Also everyone wants to say match it with a bias, we'll find me a 7" wide bias 17" tire and I will. I would rather run my radial that can support the weight then a 4" tire that's maxed out before I even get in the car.
Old 06-14-2018, 06:46 AM   #9
Zl1dad
Drives: 2013 zl1
Also if you don't have input why chime in just to say that you don't have input. I don't need opinions I need experience. Bc the guys that DO run this combo say it's not a very big issue. It's the guys that don't run this combo who are saying who unsafe it is and how bad they sway is... But guys running this say sway isn't very bad. So I'm going to take more of what the guys running this combo into consideration.
Old 06-14-2018, 07:14 AM   #10
Yellow Bullet
Don't ask the question if you have your mind set...
Old 06-15-2018, 05:14 PM   #11
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I ran 10.9@125 1.47 with 215 radials up front on 17x7s and 28x17 hoosier slicks in back. Drove fine.
But I think it depends on combo. If you had 20s up front it might not drive as nice.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 06-15-2018, 05:48 PM   #12
Stefano
Stefano's Avatar
Drives: 6th Gen NicKey Camaro & others.
It depends on many factors. After years of experience and watching guys with that combo hit the wall. I won't take the chance with any of my cars.
Stefano is offline   Reply With Quote
Old 06-16-2018, 04:01 PM   #13
Zl1dad
Drives: 2013 zl1
Well today I got my own opinion on the combo. Starting at 26psi in the rear and aired down to 18 throughout the day. Did not have much issues at all. Like the guys said before, grow some balls lol. Only time it got a little bad was when I got loss of the line and when I got it straightened out it started tracking to the left and I tried to correct it about 3/4 down the track and felt some sway so I let out and it was fine.
Thanks for the opinions everyone, I don't think it's as bad as it's lead to believe. Thanks for looking out for my safety though guys. Hope to see some at camarofest.
Old 06-22-2018, 01:18 PM   #14
Pro Stock John
Writer
I think a radial skinny and bias rear is better than stock front and bias rear.
Stock front is heavy and has more rolling resistance.
PROJECT HEAVY CHEVY
