04-01-2014, 08:56 AM | #1 |
Mid-Florida Camaro Club
Drives: 2019 ZL1 on Order Join Date: Jan 2011
Good Deal for Floor Jack
I recently purchased some 18" Wheels for use at the track, and as such I'll be swapping wheels often and wanted to purchase a decent floor jack that was quick and easy to use with our ZL1.
I came across this deal on Harbor Freight to get a 1.5 ton low profile racing jack for only $89.99, and then also sourced a coupon code to get a further $30.00 off that price - delivery is only $6.99 on top of that. I thought I would pass on the details as in my mind this is a fantastic deal for a piece of essential equipment for us ZL1 owners...here is the link and below that a picture of said jack... Coupon Code is 29552578 which you add once the item has been added to your cart http://www.harborfreight.com/rapid-p...html?hftref=cj Hope this helps at least one other person
04-01-2014, 09:06 AM | #2 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Seems to have a pretty short reach limiting you to lifting it at the jacking points on the rocker panels rather than the frame. Not a big deal especially if you have a set of the nylon lifting blocks that fit right in the jacking slots.
04-01-2014, 09:09 AM | #3 |
Right - I'll be using this jack in conjuction with the heavy use magnetic jack pads of course - they work perfect with this and make lifting the car and swapping wheels a breeze
04-01-2014, 09:33 AM | #4 |
Thanks! Just bought one.
04-01-2014, 09:43 AM | #5 |
Drives: '13 Silver Ice Metallic ZL1 Join Date: Jul 2012
Is 1.5 ton strong enough to lift one side of the car?
04-01-2014, 09:48 AM | #6 |
Yes - I know other people have used this jack on the ZL1 with great success
The entire car only weighs a touch over 2 tons and you're only lifting part of that weight. Of course you should put it on jackstands if you are planning to keep it lifted for a longer period of time than just swapping out wheels or anything
04-01-2014, 10:42 AM | #7 |
Drives: 2013 HWSE Indy Festial #26 Join Date: Mar 2011
Just scored one! Thanks for the heads up!
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan |
04-01-2014, 11:16 AM | #8 |
Madman
use their 2.5 ton low profile jack.. never no issues... this is a nice ,light jack.. great price..Im lucky I have a harbor freight 7 mins away form home.
04-01-2014, 05:34 PM | #9 |
Cool. Thanks.
04-01-2014, 05:58 PM | #10 |
No problem - glad to help a few others out!
04-01-2014, 08:24 PM | #11 |
America FVCK Yeah!
Drives: 2021 ZL1 1LE A10 Join Date: Mar 2013
I bought 2 last time I saw them at this price. Always good to have a spare.
04-02-2014, 12:00 AM | #12 |
Drives: 2013 ZL1 AGM Join Date: Mar 2012
Nice find. Thanks for being kind enough to share with the Camaro 5 group!
OC ZL1
04-03-2014, 11:57 AM | #13 |
Drives: 2011 2SS Join Date: Jan 2013
yeah, there is a store right up the road from me. I've spent a lot of money there, and have one similar to this with a little longer reach. GREAT deal.
04-26-2014, 06:33 AM | #14 | |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
Thread Tools | |
