01-20-2018, 02:27 PM | #1 |
Drives: 2014 2SS/RS - SIM Join Date: Apr 2014
305/35/20
Stock 2014 SS
Will the 305's rub on the rear? Thanks for any replies
Many would still be alive if not for Gun Free Zones.
01-20-2018, 02:58 PM | #2 |
Drives: 2017 Chevrolet SS 1LE Join Date: Oct 2016
Too large of a tire to be honest
01-20-2018, 03:38 PM | #3 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Those aren't going to fit your stock wheels. If you get proper width and offset wheels, you'll be fine.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
01-20-2018, 04:00 PM | #4 |
Instagram: Sangstah
I fit 305/30/20s on aftermarket wheels with no rubbing in the rear
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
01-20-2018, 04:43 PM | #5 |
Thanks guys, wish full thinking haha. I do have 10" rim after market wheels but we are not sure of the offset.
my son wants me to go with 255/35/20 front and 275/35/20 rears and lower the car 1 to 1.5" not sure I want to go that small but might look cool.
01-20-2018, 06:00 PM | #6 | |
Captain Gingerbeard
If you've got 10" wheels, I'd rock a 285/35/20 front, and a 295/35/20 on the rear. Michelin Pilot Super Sports. That's what I currently have and I love it.
01-20-2018, 06:20 PM | #7 |
Drives: 2011 2SS/RS Join Date: Feb 2016
the 305/35/20 fit the stock SS wheel, just do NOT corner hard. There is no rubbing. IF you put larger wheels on the back depth wise, You have to adjust the ebrake cable thats all.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
01-23-2018, 08:07 PM | #8 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
I have 285 35 20 fronts and 335 30 20 rears on mine. Stock ZL1 20x10 fronts and 20x11 rears. No rubbing issues at ll
Bone Stock |
01-23-2018, 08:10 PM | #9 |
Now im no longer joking when i say i have extra loads
Bone Stock |
01-24-2018, 10:06 AM | #10 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
All depends on offsets, and the front camber. I run 2.4 neg front camber for autocross. With that and 20x10.5 wheels with 20 offset you have to run 285/35/20s, 295s won’t work unless you run only 1.1 negative camber. 295/35/20 Michelin K1 Ferrari super sports, same wheel size with a 35 offset in rear are fine. Drop is 1”
This all may not apply to you, but gives you an idea of what can be done and what to watch out for. |
01-24-2018, 12:05 PM | #11 |
Drives: camaro Join Date: Nov 2011
um ... am I missing something???
the standard size tires for a 5th gen Camaro with a 20x10 front wheel and a 20x11 rear wheel is a 275/40/20 front and a 315/35/20 rear with absolutely no modification requirements. |
01-24-2018, 12:54 PM | #12 | |
Drives: 11 SW SYNERGY SERIES/14 1SS 1LE Join Date: May 2012
Yes you can run the 315/35 but it best be on an 11" wheel in the rear and it will not rub. Offset permitting of course.
2011 Summit White Synergy Series Edition, the hot innocent woman named Ava that we show off around town, dressed in white complete with angel's wings. Sold, but never forgotten.
2014 1SS 1LE. Bama, sporting Red Rock Metallic demon's horns, when we are ready to get naughty and open a can of whoopass! Airaid, Spectre, Xpel,Bowler shifter Peddars, UMI, Ult Perf. Diode Dynamics, JRE Tune, XS Power battery, Hooker Headers Blackheart exhaust,Powerbrake InstaGram & Twitter: @jlouie62 FB: hangtimeracing |
01-24-2018, 01:38 PM | #13 | |||
Captain Gingerbeard
