![]() Drives: 2013 1SS BlueRay Metallic Join Date: Nov 2018
Cam and stall converter on L99...?
I drive a automatic 2013 Camaro 1SS. Last May I was able to have GPI install their SS1 VVT cam. One big reason I went with this cam was on their page it was sold as it works well with the factory stall converter. Which it has I've only put roughly 4k miles on the car since the install and no problems no complaints at all. It will buck or surge some at lower rpms cruising through my town at 20 mph coming to a stop. But that seems to have gotten a lot better or maybe I've just gotten used to it. Today one of the techs at the local Chevy dealership told me I should have a converter installed that's the reason for the bucking and will burn my transmission up. Not to discredit either side I would just like to think I could trust GPI more than this small town Chevy tech. is this something i should have done to my car? Or even if my car doesn't "need" it is it something that could improve performance and or health of my car if I had it done?
![]() ![]() ![]() ![]() ![]() Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Who tuned your car?
![]() Drives: 2013 camaro SS Join Date: Aug 2019
Yes it will help. Don’t go radical. I have a stage 4 tsp cam with a 3600 stall converter. No bucking but I shake at red lights lol. I also have heads intake etc
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
I don't think i buy that it will burn up your trans. It sounds to me like the tcc might need to unlock a little earlier but if your idle rpm isnt much over stock it wont hurt the trans. What the tech is probably leading at is if the rpms are higher at idle the car will be slightly engaging the converter which can cause more heat and more wear on the converter. A stall converter will for sure help amd it is a good performance mod but not required imo. Auto guys may have more to say on the subject.
Started#gottalovethatblue
With a stage 1 cam you shouldn't need a stall. Something is off on your tune to make it buck that badly.
#6 |
#7 |
Yup yup got long tubes intake and getting exhaust this year. Defiantly a good shake at stops and when I start it up in the garage. I feel like the bucks aren't anything bad or out of control maybe even just me not firming pressing into the brake.
#8 | |
#9 | |
#10 |
Yea I think your tune on the trans/converter may be off, I have a TSP Stage 3 cam and a 3200 stall and am able to just putt through parking lots in drive or 1st in manual mode under 20mph with no bucking at all. Maybe they don't have to converter "unlocked" at lower idle speeds. Good luck sir.
