![]() Drives: 2015 2SS RS Join Date: Jan 2020
what level of cell honeycomb i want for high flow cats?
what are stock cats for 2015 ss camaro as far as cell(400?) count? what cell number do i want for high flow or do i even know what im talking about?
for ex., how can a high flow cat be high flow when it is listed as a 400 cell cat? thats the same as the stock oem cats if im not mistaken, so how can it be high flow? i see ads for after market high flow cats and when u look at the specs its listed as a 400 cell catalytic converter. so how can that be high flow when its no different that the stock cats? or am i just way off from understanding? thanks in advance
Darkness
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Most hi-flow cats are 200 per sq inch but you can get even lower 100 cell race and 50 cell ultra race - http://mandrelbendingsolutions.com/
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
yea if its 400 stock and the high flow is 400 there isn't going to be a flow difference there. I believe, as stated above 200 or less is what you want.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
majority of what you’ll find will have 200 cells and work just fine. Don’t get anything above 200 cells, and if you can find them get 100 cell cats.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
whats a good cheap pair of 200 cell cats or would u go 100 cell?...im gonna go hf cats connected to my long tubes from speed engineering...i dunno the size of s.e. pipes off hand to make sure the hf cats are gonna fit...
Darkness
#6 | |
got ya
Darkness
#7 |
The speed engineering header is a 3" exit. not sure on the exhaust side size.
#8 |
so i assume the cats have to be 3 inch wide for weld and if 2.5 inch, should slide in and use clamps?
Darkness
