08-04-2020, 03:22 PM | #1 |
Drives: 2014 Camaro SS Join Date: Jun 2020
E85 kit
Who makes the best E85 conversion kit?
08-04-2020, 03:34 PM | #2 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
GM
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
08-04-2020, 03:36 PM | #3 |
Dsxtuning.com
everthing you will need and more
08-04-2020, 03:52 PM | #4 |
Drives: 2010 ss/rs 6 speed manual Join Date: Aug 2013
Ok I’ve gotta ask as I haven’t really heard about e85 until I started reading here mostly. What is the benefit of it? What it’s the point really? Is it a supercharged thing only?
2010 camaro ss/rs, standard 6 speed, ls3 motor, bmr subframe connectors, jba 3” competition Exhaust, stainless works 1 7/8" headers, adm cold air intake, hurst short throw shifter, bo white ported tb, mishimoto aluminum radiator, mishimoto oil cooler.
08-04-2020, 04:06 PM | #5 | |
Drives: 2010 Black 2ss Camaro SS Join Date: May 2010
the alcohol content of it E85 is 85% Ethanol(or should be) compared to 10% on pump...almost a race fuel. Burns cooler, more power...like using meth....not needed unless boosted.
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
08-04-2020, 04:12 PM | #6 |
So it’s mostly for booster cars? Kinda thought that was the case. But ty that kinda sums it up a little better. Not sure I can even get e85 around where I live
08-04-2020, 04:50 PM | #7 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
08-04-2020, 05:41 PM | #8 |
You can't be any more vague, can you? What do you want us to ASSUME
you have? You did not specify what Year car, motor, nothing, so all you're going to get are guesses, BECAUSE: If you happen to have a V6, LLT motor, there is no E85 Kit. They start with the LFX for V6 engine. SINCE you specified absolutely nothing. |
08-04-2020, 05:57 PM | #9 |
Drives: 2011 2SS/RS Join Date: Apr 2019
I don't personally have any experience with these, but he seems to move a lot of them!
https://www.lethalgarage.com/
08-04-2020, 06:39 PM | #10 |
Drives: 2012 2SS Victory Red with white st Join Date: Jun 2016
Um don't forget about Lethal Camaro and Gen5 DIY conversion
08-04-2020, 06:45 PM | #11 | |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
08-04-2020, 06:48 PM | #12 | |
Drives: 2014 SIM 2SS Join Date: Sep 2015
Says they have a 14 SS under their username. OP - https://dsxtuning.com/collections/fl...-camaro-ss-1le AGP Turbo sells one with their fuel system but I don't see it listed separately, you may want to contact them. |
08-04-2020, 06:50 PM | #13 |
Get an Alky-Control flex fuel kit. If you need Julio's number, I can get it for you.
But before you make any decisions, you better have a tuner lined up that can take full advantage of the fuel. For those that say it is only for boosted cars, bullshit. I know many cars running corn for racing and pump on the streets. |
08-04-2020, 07:28 PM | #14 |
For n/a setup e85 shows real benefits at 12.5 compression and up. For 12.0 compression and lower a good 93 fuel should not limit your spark advance.
F/I setups it helps at any boost level
