#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Cosmetic Maintenance - Wash, Wax, Detailing, Exterior Repairs
Old 08-12-2020, 02:31 PM   #1
20Bluezl1
Drives: 2020 Zl1 A10 Riverside Blue
Exterior detail
So I've been reading alot of post regarding ceramic coating and I have seen that I really dont need that. So I have decided that this is the steps I'm going to take.
1. OG Decontamination Soap which will remove all wax and oils.
2. Optimum Ferrex which removes all the iron in the clear coat.
3. NanoSkin Glide with a clay bar and NanoSkin AutoScrub Sponge to really clean up the surface.
4. Raise car
5. Know I need a sealer that will give a new shine was thinking about McKees 37 10 min paint sealant. (Any other suggestions)
20Bluezl1 is offline   Reply With Quote
Old 08-12-2020, 03:25 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
The McKees will work well, or Meguires hybrid Spray wax. Go easy on nano skin, it’s a new car.
Glen e is offline   Reply With Quote
Old 08-12-2020, 04:16 PM   #3
20Bluezl1
Yea Im getting the fine Nano skin the only reason im using the nano and clay bar is that the paint is not smooth and I feel alot of particles when I rub with thin plastic.
Old 08-14-2020, 02:37 PM   #4
20Bluezl1
Any other suggestions?
Old 08-15-2020, 08:55 AM   #5
indyz
Drives: 2SS, CT-R, LC500
I've tried
meguiars hybrid ceramic wax (I dilute this 1:5)
Turtle wax seal & shine
Sonax brilliant shine detailer (diluted 1:3)
They all last for months.
Gloss is good.
Seems sonax bsd has the tightest beads after a month if you like that sort of thing.
I don't care about beading because it causes water spots after morning dew has formed and the sun shines bright and hot.
indyz is offline   Reply With Quote
Old 09-16-2020, 09:23 AM   #6
CamDriver76
CamDriver76's Avatar
Drives: SS
Hi, you first need to paint correct or polish the paint before applying ceramic coating. Once you have coating on, you can buy a ceramic spray like Meguiars or P&S Bead maker. It is a topper to like protect the coating and gives an added gloss.
CamDriver76 is offline   Reply With Quote
