Old 10-01-2018, 10:05 AM   #1
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
Camaro 6th gen to 5th gen Black LED Projector Headlights
I am not sure if anyone has posted these before, just looking for some answers I guess. Regarding the branding, it seems like there is zero information. Has anyone seen/installed these? I am looking to switch from Non RS to RS lights and did a search for a used set on Ebay and they popped up. I would assume you need an RS or have the conversion harness to run them.
https://www.ebay.com/itm/Headlight-f....c100005.m1851
Attachment 959007
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 10-01-2018, 11:34 AM   #2
orange devil
No you don't need to be RS to use those new 6th gen style headlights..if you are RS you will need a harness to go backwards. Hit up RGV shelby on Instagram.. he is super helpful and builds custom headlights he will answer all your questions that you have. I'm actually having him build me a set of headlights
orange devil is offline   Reply With Quote
Old 10-01-2018, 04:11 PM   #3
NoDakZ/28
NoDakZ/28's Avatar
Awesome, thank you. I have a 1ss-1le
2014 1LE - Sold
Old 10-07-2018, 06:35 AM   #4
PhantomBlack
Drives: 2014 Camaro 2SS
Phastek is about to sell these headlights on their website and they just released the 6th gen tail lights also. Like the other member mentioned no harness needed for non RS vehicles.
Link to headlights: https://www.phastekperformance.com/H...ero-5hldrl.htm
Link to tail lights: https://www.phastekperformance.com/s...ential&Submit=
PhantomBlack is offline   Reply With Quote
Old 10-08-2018, 11:02 AM   #5
NoDakZ/28
NoDakZ/28's Avatar
Thanks, saw the sneak peek someone posted awhile back. Glad to see some options for the 14-15's.
2014 1LE - Sold
Old 10-08-2018, 11:27 AM   #6
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
I believe they will not work with the factory RS ballasts, you will need to source HID and harness for these to work on RS.
Camaros & Coffee Norcal store is selling the light with the plug and play harness and HID upgrade for RS for 579.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 10-10-2018, 09:59 AM   #7
derieu
Engineer
derieu's Avatar
Drives: 2014 Camaro 2SS RS 1LE
Is phastek sourcing their own headlights or are they just purchasing the ebay models and marking them up an extra $100?
2014 Red Hot Camaro 2SS RS 1LE
-Sunroof Delete, Recaro, Nav, NPP
-Pegasus Subframe Bushings, JPSS Radius Insert, Detroit Speed Caster Mod, PMAS Intake, Solo High Flow Cats, Ecsta PS91 Tires, MGW Shifter, Pegasus Offset Poly Diff Bushing
derieu is offline   Reply With Quote
Old 10-10-2018, 10:02 AM   #8
SSEssence
Instagram: Sangstah
SSEssence's Avatar
I'm pretty sure they are all the same headlights coming out of China sold through different sources but I can't confirm
Old 10-10-2018, 07:15 PM   #9
_Chigga
Drives: 2015 Z/28, #225 Red
I think they are COPLUS lights coming from Taiwan, just re branded in the U.S.
_Chigga is offline   Reply With Quote
Old 12-04-2018, 11:01 AM   #10
camaro2lt-15
camaro2lt-15's Avatar
Drives: 2011 Camaro 1LT/RS SGM
I'm thinking of buying those to my 2015 2LT since I tried to get a 6th gen but I couldn't afford it.
There out of stock on tail lights and head lights are not available yet.
camaro2lt-15 is offline   Reply With Quote
Old 12-05-2018, 12:36 PM   #11
_Chigga
Still waiting on those headlights ...
Old 12-16-2018, 02:10 AM   #12
Jc_SourPatch
Drives: 2014 2LT Camaro RS
I have these so far nice bought from eBay came with harness already but when I plugged them in directly they worked fine also so idk what the harness does exactly.
Jc_SourPatch is offline   Reply With Quote
Old 12-17-2018, 09:15 AM   #13
Mr2Hard2See
Instagram: Mr2Hard2See
Mr2Hard2See's Avatar
Drives: 2011 2SS/ RS
1st link=$1000
2nd link=$600
So is $600 the best price for these 6th gen headlights? I’m interested in this mod but not for $600 right now. I thought $200/$400 range is wherevthey would be. If $600 is the baseline for a good quality set then I’ll do it later on down the line.
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242
BTR dual springs pushrods lifters retainers etc
Che bronze trunnion Ls3 timing/valley cover
Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers
Mr2Hard2See is offline   Reply With Quote
Old 12-23-2018, 01:14 AM   #14
Jc_SourPatch
https://www.vland-carlamp.com/Headli..._19017955.aspx
