09-14-2014, 09:30 AM | #1 |
Drives: 2013 Camaro SS Join Date: Nov 2013
Error Code P0240
Hey guys, I have a 2013 Camaro 2SS.
I have about 14k km on it. Recently I've been getting a check engine light. When I went to my local maintenance shop, They told me it's got to do with the Carbon Dioxide Module thing which reads the O2 and Carbon emission. He cleared the code and told me not to worry about it. Now it's back and I just want to know what exactly it is and if their is a quick solution to this problem rather than taking it back to the dealer. Thanks for suggestions! |
09-14-2014, 09:40 AM | #2 |
Drives: 2014 2SS L99 Join Date: Mar 2014
There are a host of things that can cause a P0240 code. O2 sensor/s, cat, ignition fault, fuel/air mix, yada yada yada...Good luck... Yea, best to just let the dealer track it down.
09-14-2014, 02:27 PM | #3 |
Drives: 05/07 Chevy's Join Date: Aug 2009
There's no such code as P0240 also there nothing called a Carbon Dioxide Module.
09-14-2014, 04:28 PM | #4 | |
Well, there actually is a P0240 code ( P0240 Turbo/Super Charger Boost Sensor "B" Circuit Range/Performance ) I mistook his post for a P0420 code and had the numbers transposed when I read it. Maybe that's the code the OP is getting. If not, I have no clue. P0420 code description is ( Catalyst System Efficiency Below Threshold (Bank 1) |
09-14-2014, 05:52 PM | #5 |
09-14-2014, 05:56 PM | #6 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
Just install some long tube headers and hi flo cats, problem solved.
09-14-2014, 06:01 PM | #7 | |
http://www.camaro5.com/forums/showthread.php?t=173650 |
09-16-2014, 03:42 PM | #8 |
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
Maybe you mean P0420 Cat efficiency?
