Old 01-09-2016, 07:41 AM   #1
bleavens1962
Drives: 2014 1LS Camaro
Supercharger Catch Can
IPF LFX Supercharger Kit on the way..I read that the catch can that comes with the kits isn't what it should be..What are you guys using ?
There seems to be a few options..
Thanks
bleavens1962 is offline   Reply With Quote
Old 01-11-2016, 05:24 AM   #2
Black Knight
Black Knight's Avatar
Drives: Supercharged LLT
Mighty Mouse catch can (boost can) . Sum ppl run apex apex as well
CLICK IMG FOR BUIlD THREAD
Black Knight is offline   Reply With Quote
Old 01-11-2016, 06:33 AM   #3
bleavens1962
Thank you Sir
Old 01-11-2016, 10:10 AM   #4
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
Thanks
The Elite E2-X system is designed just for the GDI engines need of the most effective in air/oil separation as well as for turbo and centri blower systems where the intake manifold becomes pressurized. It provides constant evacuation in both boost and non-boost operation as well as the AN fittings and billet checkvalves are all included standard. You won't fond a better solution, and it's a closed system, so emissions compliant as well.
Look at what Jantzen is putting on his twin turbo V6 after trying all the others.
Elite Engineering is offline   Reply With Quote
Old 01-11-2016, 10:50 AM   #5
Elite Engineering
Drives: 2010 Camaro
Thank you Sir
Please take a look at this thread for further information:
http://www.camaro5.com/forums/showthread.php?t=434666
Old 01-12-2016, 07:52 AM   #6
alice
alice's Avatar
Drives: 2010 camaro limited edition turbo
The Elite EX-2 is the best on the market, as far as I am concerned. I have tested others and after installing the Elite EX-2, the amount of oil and water that it caught was significantly more than any other can tested. I am amazed at how well this catch can works. By the way, I have a twin turbo LLT Camaro.
alice is offline   Reply With Quote
Old 01-12-2016, 08:11 AM   #7
GenF-GTS
Drives: none
This looks incredible and much better than previous designs, what does the internal design look like now?
GenF-GTS is offline   Reply With Quote
