04-19-2018, 06:37 PM | #1 |
Drives: 2013 ZL1 Join Date: Dec 2017
Exhaust sensor question.
I have the old exhaust off and am ready to install the KOOKS headers I have.
I have attached a photo of the headers. Which location do I install the wide band sensor I have? The first one one the header I believe is the old pre cat sensor. The one in the middle that is plugged may get the wide band sensor. Does the old sensor that was at the back of the catalytic converter go in the mounting point on the off road pipe? Any info would be appreciated. |
04-20-2018, 07:13 AM | #2 |
Drives: 2015 ZL1, Red Hot A6 Join Date: Aug 2016
Front sensors go in the headers, rear sensors don't go back in. Wideband can go in the offroad pipe bung on one side and plug the other, or you can run 2 widebands if you want.
2015 Red Hot ZL1, Rotofab, Kooks LT's, 10" lower, ID850's, JMS BAP, BTR stage 3 torque cam, meth injection, self tuned with HPtuners
1969 Chevelle, 418 LS3, Ridetech suspension |
04-23-2018, 09:45 PM | #3 |
Thanks for the help gmorris. This forum is a great info source.
